Question about Craftsman Garden
Oil plug i cant find where to drain the oil in model #126t05 bns lawn nmower. no side drain plug. underneath, i can only locate the mounting bolts, and belt cover bolts. is there a trick to this. My first time ever doing this. thanks for any help!
  • 376 Answers
There is a drain plug in the bottom of the engine. It has a square hole in it that a 3/8 socket extension will fit in. It may be hidden by the belt cover if you can't see it. Dwain
Posted on Jun 03, 2009
I was asking about a lawn mower, NOT a car. this is typical of sites like yours.
ether on bottom are on side of engine if cant get to drain plug drain oil through filler tube
Aug 18, 2014 | Garden
27 hp briggs stratton cant find oil drain plug
generally oil drain plug is on the bottom of the mower.there some on side of motor located at bottom of the motor. some take wench and some take Allen wench. the ones on the bottom of the motor is accessible from under side of the deck.
Aug 17, 2014 | Garden
How to drain oil from a lawn mower engine
Depends on what type mower you may have. Most push mowers have a drain plug on the underneath side and is usually a 3/8" plug.
Some have a plug on the lowest point of the engine next to the engine mounting deck. Most shops use a vacuum pump to extract the oil out of the engine as this manner is faster and less messy. The vacuum pumps aren't that costly and handy. Hope this will help
Jul 15, 2014 | Briggs & Stratton Garden
Have a GTS 5.5 here,and cannot find the drain plug in order to change the(OLD) oil. Had the blade and cover off,and saw no bolt or plug. Also didn't see a plug on the side. Any help appreciated.
Well If You Cant find drain plug [should be a square drive]
Then I would turn the thing upside down [empty gas tank first of course]& drain it thru the filler plug. Perhaps the drain is an inset hex bolt and you must REALLY clean the underneath, dig around for it!
Jul 14, 2014 | Toro Lawn Mower With Toro Power Tools
Cant find oil drain plug on 2010 fxdc
Hi Anonymous, the oil drain plug on a DYNA is located on the left side of the oil pan underneath the transmission in the left rear corner. Have nice day.
Sep 23, 2013 | Harley Davidson Motorcycles
Where is oil drain plug located on toro 6.5 hp engine
ether on bottom sometimes cover by motor frame were you cant see it or on the side of motor at the dipstick if your wanting to change oil and cant get to drain plug shops flip them on there side and drain them threw the filler tube
May 26, 2013 | Garden
Where is the oil drain bolt for a 1998 dyna
May 25, 2012 | Harley Davidson FXDWG Dyna Wide Glide...
I cannot find the oil drain plug? The only bolts under neath are the engine mount bolts?
Hi, they are made to drain from the dipstick filler. Remove the dipstick and lay the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Poulan Pro PR550N21R 21Inch Briggs ...
Need tips and location of oil filter and drain plug.
well the drain plug is ALWAYS gonna be on the bottom of the oil pan bolted to the bottom of the engine, the filter is either gonna be on the oil pump near the oil pan or it will be screwed into the side of the engine block, either way you should be able to see it just from a quick look from underneath the car.
Feb 25, 2010 | Saturn L300 Cars & Trucks
I've been given a Craftsman Eager 1 6.5hp mower (front wheel drive)and I can't locate the oil drain plug.
On a walk-behind mower, the oil drain plug can usually be found on the underneath side of the deck. The drain plug usually has a square head.
Jun 23, 2009 | Garden
Garden Logo
81 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
