Question about HP Pavilion dv6000z Notebook
I have a problem with Microsoft ISATAP adapter
After showing exclaimation mark in it, I tried to update the driver, but it says the driver has already been installed. So, I un-installed it. when I try to re-install the device, I couldn't make it. I saw the device when I open Add Hardware, but I can't install it really. What would you suggest?
  • 54 Answers
Try removing and reinstalling TCP/IP v6 in the active network adapter's properties.
Posted on Jun 03, 2009
    Scholar:
  • 113 Answers
You don't mention which driver ? If it's a graphic card driver , you can go to the manufacturers site , if it's a nic card driver you go to the hp site !
With not enough information from you I suggest going to HP SUPPORT and retreiving any drivers you need from them.
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Repair isatap drivers windows 7
if the drives are working, leave it be. There can be false positives. If the drives are slow or some thing else is odd, try the following solutions. Try to locate the driver needed by going to system devices and looking for a yellow or red icon next to a device. If there are no marked devices, you are probably ok.
Computer icon, properties, select device manager.
Open the properties for that device. details tab, properties and select hardware id. Copy the hardware id information and google it (sample:IDE\CdRomATAPI_iHAS324___B_______________________AL1A____ trimmed and adjusted becomes IDE\Cd Rom ATAPI iHAS324) Find drivers for that hardware if you can and update. You can also just uninstall the device and click rescan from the device manager menu. It should reinstall.
May 12, 2012 | Microsoft Windows 7 Home Premium 64BIT...
I need microsoft ISATAP adapter #3 driver
you can try this:
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
Feb 01, 2012 | Toshiba Computers & Internet
In Device Manager under Network Adapters the following have a yellow triangle in front of each one; 1. Microsoft 6 to 4 Adapter, 2. Microsoft ISATAP Adapter, 3. Microsoft ISATAP #2, 3. Microsoft Teredo...
the yellow mark on device manager means the driver has not been installed and the driver is connected to the motherboard use your motherboard drivers CD and install them or you can download them from the net
Dec 15, 2010 | HP Pavilion m7640n PC Desktop
In Device Manager, under Network Adapters I find a new entry called "Microsoft ISATAP Adapter".The yellow explanation mark indicating a problem is present. Status shows "Windows is unable...
Hi.
Let me explain you about the Microsoft ISATAP Adapters.
ISATAP (Intra-Site Automatic Tunnel Addressing Protocol) is an IPv6 transition mechanism meant to transmit IPv6packets between dual-stack nodes on top of an IPv4 network.
It is a Windows Operating System Generic Driver.
This Driver will be installed automatically.
As this is a Windows default Driver, it has no specific functions.
As you are able to view the "yellow exclamation mark", you may just un-install the Driver..
This should not change the functionality of the Computer.
1) Right-click on the "ISATAP Adapter" in the Device Manager. 2) Then, click on "Un-install". 3) This should un-install the Driver. 4) Once you have done the above steps, restart the Computer for the settings to be enabled.
Performing the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 23, 2010 | HP Pavilion dv6000z Notebook
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
There is a exclamation mark in the device manager beside the microsoft ISATAP adapter#5. Should this exclamation mark be here?
No. If you have the driver for it try reinstalling it. If you don't I would delete the device and reboot. This will force the drivers to be reloaded unless they were deleted...If they were deleted and you are not very good in computers, you may need a bit more troubleshooting than on line help.
Dec 07, 2008 | Computers & Internet
ISATAP adaptor
you have ipv6 enabled, this is to help the worldwide convergence to ipv6 form ipv4 . were running out of addresses if not already have ran out.
so from what i can tell it works with the tunneling adapter. altho it is still doing stuff on your computer, it's needed to make the internet work right now, if anyone of you have a "microsoft wi-fi miniport adapter" all of a sudden and you also don't like that you can't get rid of it unless you go to the web and download the old driver.
neither the miniport or the isatap adapter are actually "needed" you can get by without isatap if you either disable or uninstall ipv6. virtual wifi isn't needed, but it's uber cool cause it's for your wireless card and if you connect wireless to the internet, it will let you wirelessly share out that connection wirelessly , (like your a wireless router)
i think i should not that "eventually" you will need to install ipv6 to browse the internet.
more importantly it actually isn't designed to be a "TAP" but it certainly could be the target of hackers in the future including the mini-port (only because they are both new)
http://www.istartedsomething.com/20090516/windows-7-native-virtual-wifi-technology-microsoft-research/
http://en.wikipedia.org/wiki/ISATAP
Oct 05, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
