Question about Kenmore 74602 Gas Dryer
Flame goes off
I have a kenmore gas dryer and when started everything works then a minute later the flame goes off for no apparent reason, Please help
  • scotland86 Jun 03, 2009
    the model number is 110.72822101
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
First make sure that your exhaust pipe going outside is completely clear. Also you may need to clean the lint out of the drier. If you take the lint catcher assembley off on the inside, ther will be alot of lint inside. Just clean out what you can by hand, then vacuum out the rest. This should take care of your problem.
Posted on Jun 03, 2009
Kenmore model#110.72702101 starts up,heats then burner stops won't relite
If what your seeing is that the flame starts out and goes off and a few later later the igniter glows but no flame??? then the cause of that is going to be the coils on the gas valve are weak and not opening. This tip i wrote explains what is wrong when a gas dryer starts heating but after a while wont heat. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 13, 2011 | Kenmore Dryers
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
GE dryer starts up ignitor gets hot you see flames everything is working. 2-3 minutes later the flame goes out. Is this a bad thermostat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101''';;
Apr 22, 2011 | GE DRSR483GD Gas Dryer
My gas dryer starts but then the flame goes out the flame stays on for about 5 minutes the goes out
The flame should cycle on and off in response to the thermostat. If it is going out and not coming back on several minutes later then the exhaust vent may be clogged. Check the lint filter and exhaust vent all the way to the vent outlet to make sure they are not clogged.
Oct 16, 2009 | Kenmore Dryers
Kenmore dryer, saw igniter heats up, seconds later flame came out, started heating up then 4 to 5 minutes later flame and igniter sthut off,
sounds like bad gas coils the hold or assist, but i would change them both at the same time
they are the lilttle cylinders on top of the gas valve
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 74602 Gas Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
