Question about NAD C541 CD Player
NAD C541i not recognising CD's
Hello
I got a 2nd hand Nad 541i and it played fine for a few weeks before it started not recognising CD's. The screen keeps blinking. Even when the tray is empty it doesn't show the "No Disc" message.
I did a search on the site and I guess it must be a problem with the belt slipping, because when I close the drawer the motor keeps running.
I opened the player and I see a belt that seems a bit loose. I tried to manually turn it, it fixed the problem for a little while. But then the problem occured again, only this time the drawer is closing fine when empty and  the "No Disc" message appears. Still, with a CD inside, the drawer closes, the motor keeps running and the screen keeps blinking, as before.
Could it be that the surface that the player is resting on isn't perfectly flat or is it the belt ? And if it's the belt, how do you remove it and where to get a new one ?
  • 1 more comment
  • Pazan Nov 08, 2007
    I have a very similar problem. 95 percent of the time it does not recognize the cd. Lights blink (dashes) then it turns on and off by itself. Also when it starts to play it starts to make weird noises in the middle of song and then tries to shot down. I cleaned the laser and did not help. Thanks.
  • Anonymous Feb 01, 2009
    Yeah same thing
  • avirtuoso Mar 24, 2009
    I have similar problem with my NAD C541. I opened up the unit and got the drawer to open and close. Great. Put it all together and it didn't recognize CD's.
3 Suggested Answers
  • 99 Answers
SOURCE: NAD C541i CD Player plays but...
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Posted on Feb 02, 2009
SOURCE: NAD C541i CD Player won't turn on
I recently bought a second hand C541i as is and I had the same thing; no power up. I took it to a service centre, they re-soldered the connecting pins for the transformer socket. It now works well.
After that I realised that it could have been the problem with the Burson Audio clock that was installed buy the previous owner but had intermittent playback problems. A study of the schematic revealed that the +12v rail for the clock, is from a different secondary coil winding than the +5v for the DAC etc. And the -12v for the analogue output stage could be from a different pin on the connector as well.
I hope this helps.
Posted on Mar 03, 2009
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
Second hand NAD player worked well at test. Arrived at home no reaction when power on. Led turns first green, then orange. Doesn't react at all...
If it's the C541i version then there should be a switch on the rear of the
unit.
Flick this switch and all should be fine.
I think it's something to do with interconnecting other NAD products
why this switch is used.
Jun 03, 2011 | NAD C541 CD Player
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
I have nad c541i,for last few days,it not reading the cd,as the disc goes in,there's a bit sound from the spindle which goes off after 5 secs,but doesn't read the disc,the screen keeps flashing like --...
this has the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping it clamping the disc properly when closed.
the sound you say is the spindle motor, is actually the loading motor trying to lift the whole laser mechanism up towards the puck to clamp the disc as there is not enough tension left in the belt.
help it along by hand and you'll see what i mean.
hope this helps?
Nov 21, 2009 | NAD C521 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
Nov 16, 2008 | NAD C541 CD Player
Hi John,
Coincidentally enough, I have a customer's C541i on my bench right now!
At this point, you will need to open the cover and check the fuses. With the cover off, looking from the front, all four fuses are in the back left corner of the player, next to the toroidal (round) power transformer. If any of them have blown, replace that fuse with exactly its type and rating. DO NOT jumper over the fuse, or wrap foil around it. It is EXTREMELY rare for a CD player to blow a fuse unless there is a very serious failure someplace.
If the player blows the new fuse/fuses immediately it will need to be serviced. If the fuses hold, and the player plays, it was just one of those random things.
Now, IF all the fuses are good when you first check it, you have a mechanical failure in the power switch, or a broken solder joint on the board where it's attached. Luckily, a replacement switch is easy to find.
Apr 24, 2008 | NAD C541 CD Player
Loud humming on my tv and dvr with ny nad 761
The problem is the capacitor on the DSP board C107 2200mf / 16 Volts. Try replacing it and it should be fine
Oct 25, 2007 | NAD T761 Receiver
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
Nad C542 Troubleshooting
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Mar 20, 2007 | NAD C542 CD Player
Not Recognising a CD
NAD CD platters tend to go dry on the guides, stopping the bottom CD clamp from fully engaging. Disconnect the signal and power leads and undo the four screws connecting the transport to the bottom of the case. Remove and get some very fine grease and smear it lightly on all the runners and guides. Also look at the crank which causes the bottom clamp to move up and down, turn the flywheel by hand and watch it move, see where the plastic lug moves to cause the bottom clamp to move. Grease that too. Wipe any spare grease off so only the minimum is used. Do not use oil. Dean Beedell
Dec 26, 2006 | NAD C541 CD Player
NAD C541 CD Player Logo
408 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
