Question about HP LaserJet 2840 Printer
Message says page is too complex - HP LaserJet 2840 Printer
  • 525 Answers
Turn printer on.
On your printer, press the Menu button
Press 2 (on the fax dial pad)
Press the right arrow (next to Enter button) until you arrive at "High Speed USB.
Press Enter
Press right arrow to select "Off."
Press Enter.
Press Enter again.
The printer will reboot automatic.
I hope this help!
Posted on Feb 13, 2015
  • 54 Answers
In to the Service section from the Main Menu go to "High-Speed USB" and set it to OFF. This will help unless your document is using more than the printers ~45MB of usable memory.
Posted on Jun 03, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    After giving a print i get a message (Page too complex) Plz help...
    Can I assume that you are printing spreadsheets?
    Press the "check mark" to clear the message. If that doesn't work, you'll have to add more memory to the printer.
    Dec 21, 2010 | HP LaserJet 3055 All-In-One Printer
    Dell 2135 full memory error message cannot print PDF files.
    All three replies are incredibly stupid, but especially Frank's. The issue is simply that you're trying to print something that has too much complexity in it for the printer's pre-installed memory to store the final rendering of before printing. The way a laser printer works, unlike an ink jet, it has to take the entire page to be printed and render the final output in memory before the page can be fed through since it doesn't go line by line. If you're trying to print something that has a very complex page in it, such as a full 8x10 photo, the base amount of memory may not be enough. Dell sells a 256MB add-on memory chip you can put in the printer to get around this. Unfortunately the only other way around the issue would be to reduce the complexity of the page; perhaps try printing the PDF scaled down to 70% so the printed output is a lot smaller but also takes up less of the page, meaning the printer may be more likely to be able to fit the page into the existing memory.
    Nov 24, 2010 | Dell 2135cn All-In-One Laser Printer
    "Page Too Complex" message
    Press ENTER to clear the message.
    Allow the device to finish the job, or press CANCEL to cancel the job.
    Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
    To access the Secondary Service Menu press the Menu button.
    Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
    Press Enter and then use the arrow key to go to Off and press Enter again.
    Press the Cancel button twice to exit the Secondary Service Menu.
    Feb 15, 2010 | HP LaserJet 2840 All-In-One Printer
    I am getting message page to complex to print for jobs that were being printed previously
    In the task bar right click printer and kill any print jobs which are still active.
    Jan 30, 2010 | HP LaserJet 2840 Printer
    2840 printer -- can't print because document is
    Basically it is telling you it doesn't have the memory required to process the page (usually because of graphics). If this is the case, you can try setting the resolution in the print driver to a lower setting (sometimes referred to as quality) so that the memory can handle the graphics.
    Jan 30, 2010 | HP LaserJet 2840 All-In-One Printer
    Memory
    The page is too complex for the amount of memory installed. Buy a memory upgrade from www.hp.com
    Jan 27, 2009 | HP LaserJet 2840 All-In-One Printer
    ''Page too complex'' message on HP color laserjet 2840 Multifunct.
    On the printer, hit the menu button
    Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
    then use the right arrow to navigate to high speed usb and hit enter.
    it should now show on, use the right arrow once to change it to off and hit enter 2 times
    let the printer reboot and its should be fixed
    Nov 15, 2008 | Office Equipment & Supplies
    HP LaserJet 2840: Page 'Too Complex'
    Description
    The device could not print the current page because of its complexity.
    Recommended action
    Nov 11, 2007 | HP LaserJet 2840 Printer
    HP LaserJet 2840 Printer Logo
    111 people viewed this question
    Seeker5211
    Seeker5211
