Question about Sony Televison & Video
SONY KDS55A3000 PICTURE IS GREEN SELF CHEK SAY 011
SONY KDS55A3000 PICTURE IS GREEN ,SELF CHEK SAYS 011 DEV ERR 01
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
Error message "Err 01" on Sony IC BX700
are the power cells identical in every way to the old cells? Any variation can be a problem. Evidently the cells are in correctly or you would not get any message; so this may be related to a circuit board issue. A continuity test would locate the source, and if you do not have test equipment; take it to a camera shop for service.
Apr 15, 2014 | JVC Video Cameras
BLANK COPIES FROM KM 2550
first chek dev unit toner? pls insert toner 1087+ 1087+ 130 set dev enter ok then 10 mnt wait and check drum and dp closing time corect sitting or chage edge of dp unit you cleang time smothing wrong?? comng blnk copy
Aug 03, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
Where is the lamp located on the sony kds55a3000 for changing
Lamp is located on left side if you see tv from rear side.
Click Sony Support and download user manual free copy and check page-44 for more details along with exploded views for better idea about how to replace lamp.
Sep 28, 2010 | Sony KDS-55A3000 55" HDTV
FILE ERR
formatear file error system
Feb 06, 2010 | Nextar MA933A MP3 Player
Mu mp3 player said file sys err so what shood i do
format the device if it says file system error delete the song if it says file format error for a particular song
Sep 03, 2009 | Bell Technology Techsolo Slick Stick MP3...
My tv screen goes blank, sound turns off, and standby lamp blinks
If your SONY shuts down and the Green Power Light flashes 35-38 times before the picture comes back on....the problem is the LAMP. You need to order a new bulb and replace your old one. I had the same problem and this fixed it. My Red Lamp Light never came on and Sony.com/support only wanted to schedule a service call for me. They claimed no knowledge of this fix. Replacing the bulb is a breeze
Feb 27, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
