Question about NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587)
Port forwarding billion 400g
Require setting
  • 854 Answers
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Jul 10, 2009
2 Suggested Answers
  • 8 Answers
SOURCE: Port forwarding,I am retarded
totally disconnect router from computer reboot system.with your router you should have a install disc.reload the disc and follow the instructions.when you reboot your computer should find your router.hope this is of help.
Posted on May 10, 2009
Billion 400g
Your repeater probably worked as it was supposed to but because you don't really understand the technology, users like yourself plug gadgets in, push the limits to the maximum and then wonder why it fails.
The best way to extend your network is to run an ethernet cable to a repeater.
Trying to extend a weak wireless signal via wireless will almost always be doomed to failure.
Mar 20, 2014 | Computers & Internet
I can not play xbox because security is to high how do i chance it
you need to give your xbox a static ip address.
on your linksys router go to internet explorer. browse to http://192.168.1.1
default login is blank password is admin
go to Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074. Go ahead and enter the settings shown above into the Port Range Forward menu.
port forward the following ports up above to the ip address that you set your xbox 360 to.
Apr 03, 2011 | Linksys WRT120N Router
Need to know how to change the nat setting off of strick on my virginmobile mifi2200 to play xbox 360
You need to go into the port forwarding section in your administrator settings, you should be able to access that by going to 192.168.1.1 and finding the port forwarding section, you then must forward the ports that the Xbox 360 requires to go online;
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
Mar 04, 2011 | Video Game Consoles & Games
Change the local IP address of Billion 400G
You need to login to the router page with the IP 10.0.0.2 and the on that and you can change the IP from that page
On login it will ask for username and password it is admin and password is "password" by default if you have any issue in getting user name and password you can reset the router as below
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
it will come back to factory settings of 192.168.1.1 and then you need to configure the router as per your internet service provider
you can check the manual at the below link
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Nov 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Can't use irc undernet server this is the error Local host: siemens (10.0.0.100) --us.undernet.org- *** Looking up your hostname --us.undernet.org- *** Checking Ident --us.undernet.org- *** Found your...
I would suggest you port forward port 113 (IDENT) port from your router to your computer. You'll need to look up instructions on how to do this, as all routers are different.
in mIRC type /identd on <some IDENT ID here>
in the above command, notice the word is IDENTD not IDENT
then try reconnect. The <some IDENT ID here> will show up in a whois as <your nickname>!<some IDENTD ID here>@<your isp>
Looking at your output that you've pasted, I'm also assuming you're using the mIRC IRC client.
Oct 10, 2009 | Computers & Internet
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
May 10, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587) Logo
3,755 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
