Question about Keurig B50 Coffee Maker
Keurig b100 I have the B100 Keurig machine. When I fill it with water the sensor (blue fill light) continues to flash. This machine is no longer being manufactured, so they will not repair the problem for me. Can you help?
I think that the unit senses its emptiness via an optical device that triggers when the red indicator ball hits the bottom of the tube. It could be that the tube is dirty from deposits (calcium or whatever,) fooling the B100 into thinking the ball is still at the bottom.. Basically you'd have to open up the machine and see whats what, the tubes can be cleaned but if it is a defective sensor you wouldn't be able to get a replacement, but you could probably jury rig a way to defeat the sensor itself.
The units are serviceable if you are handy, but it isn't as simple as replacing a fuse...
timurf@netzero.net
Posted on Nov 29, 2007
SOURCE:
Keurig blue light flashes display shows prime
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. A common Keurig problem.
Jun 30, 2014 | Keurig B100 Coffee Maker
We are trying to get it started for the first time and the blue light is constantly on, but will not flash.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 17, 2011 | Keurig B100 Coffee Maker
My Keurig small machine will only let a small amount of water thru and then the blue light comes back on. when I push the blue light ..it just growles
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 05, 2011 | Keurig B100 Coffee Maker
Keurig B30 won't brew, no blue light comes on, top green light blinks...
Our problem was a glass cup. Changed cup to opaque cup and it worked ok, (optical sensor ?)
Nov 26, 2009 | Keurig B100 Coffee Maker
Keurig b100 does not shoot water in the K-Cup, It
Either it is scaled up and needs to be cleaned or the air pump is bad.
Nov 08, 2009 | Keurig B100 Coffee Maker
Keruig b100, no longer disperse's full cup of water
use 1/2 vinger an water and use filter no coffee should clean it out
Sep 04, 2009 | Keurig B100 Coffee Maker
Can I hook up a water supply to a Keurig B100 brewer?
The B100 is a pour over unit and the drain is just that.. a drain directly connected to the tank... In order to have plumb feature the machine would need a fill solenoid attached to a float.switch through a circut board of sorts...Hope this helps
Robb
Nov 25, 2008 | Keurig B100 Coffee Maker
B100 not heating water
The coffee maker is defective and not repairable.
Feb 24, 2018 | Keurig B100 Coffee Maker
B100 splases coffee everywhere when dispensing
you have lost your upper needel gasket. it look like this an is color si orange. try to found It or call keurig to get new one cfebcf0.jpg
Jan 17, 2008 | Keurig B100 Coffee Maker
Keurig B100 flashing not ready
I need to Know What is the color light in seeht gauge tube, Yellow Flash Need to be descale, if red solid or flashing is a heating probleme. If red flashing in seeght gauge tube is usaly the temperature sensor probe is fail. and for the moment i Have not found similar parts to replace but i work on it.
Aug 16, 2006 | Keurig B100 Coffee Maker
Keurig B50 Coffee Maker Logo
302 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
