HTC Tilt 8900 Smartphone Logo
A
Anonymous Posted on Sep 01, 2017
I can't view youtube videos on my HTC Tilt 8900 phone.
A popup window come up and states that realplayer doesn't support this file.. Something along those lines. I use to have the youtube mobile app on my phone. I DL'ed it from youtube a few years ago.. But since I reset my phone to factory defaults, I can't find the app anymore.. I would like to know what I have to do to view youtube videos on my phone again.. Please help! :)
5 Related Answers
Anonymous
  • Posted on Sep 03, 2008
SOURCE: unlocking AT&T tilt
help me lock my 8925 htc email me with help thanks [email protected]
Anonymous
  • 29 Answers
  • Posted on Nov 13, 2008
SOURCE: i can't remove the real player from my mobile htc -
hey lucky man... u r lucky to find me.. hehe
well i call u lucky man, because my fren use tytn too
here's the problem he has (which i think it occurs to you too)
when you do multitasking (open a lot of application together), it consume the memory of your PDA , so much that it cause low memory, therefore, it became slow, slow, and slower, until it finally get 'hang' condition.
what you must do with this memory consumtion is, check everytime u open and close application, did you close perfectly, or it just closed to background (it is still running, you just don't see it on the display) - u can see if it's still on the list of running application (menu)
second, if there's still low free memory, then i suggest you to erase not useful application or just format, remember to backup ur datas.
thrd, if ur internet (which u said is slow is the problem) still run slow,try it on other pda or device.don't tell me that the internet connection is sucks on all phone but all this time you blame your PDA, hha..
if it only run slow on ur phone, then format it, if still slow, try another browser like opera mini, or any browser which compatible to yours.
Good luck..
Anonymous
  • 48 Answers
  • Posted on May 31, 2009
SOURCE: Youtube Videos
If you update the phone, the flash player should update and play the YouTube videos. Check this out.
http://htcupdate.googlepages.com/
Anonymous
  • Posted on Jan 28, 2010
SOURCE: EDGE/GPRS not working in HTC TyTN II with Windows Mobile 6.1
i know this is old, but i recently bought an acer phone and my gprs internet stoped working as well, the 'E' (i think it stands for edge) changed to 'G' and the gprs internet stopped working, its a postpaid connection.
mattdehat
matt
  • 1666 Answers
  • Posted on Apr 19, 2010
SOURCE: how to upgrade my htc 8900 tilt
all you need to know is at xdadeveloper.com
1helpful
I have an unlock code for my HTC Tilt 8925, but when I put in my Net10 sim card to unlock the phone, it doesn't recognize there is a sim card inserted. is there a way around this?
i think your phone is locked to your provider. you need to unlock it to use it with other provider, you can unlock it using codes. codes are safe and simpler way in unlocking a phone. i unlocked my phone through codes from this site. WickedUnlock.com check it out.
1helpful
I download Youtube files with realplayers but when I want to delete them after viewing, I got a popup windows that says "Recycling files from Realplayer Downloads.... Recovering items...." and it...
try to remove files through CCLEANER
go to custom file deletion and navigate it to the files to be deleted and then hit run cleaner.
it can be found on filehippo.com
Como ver un video flv en mi cel w910i
If you already downloaded the FLV file follow these steps:
1. 1. Download and install a program called Realplayer SP here: http://download.cnet.com/RealPlayer-SP/3000-13632_4-10073040.html
2. 2. Once installed, Open Realplayer SP, then click file then Open, find the FLV file and open it, and hover the mouse over the video that is playing and on the bottom you will see a button that says “Convert”
3. 3. Click Convert at the bottom of the video, a small window will popup with your video in the list, at the bottom it will say convert to, click the drop down list then select black berry curve or HTC incredible, both of these file formats should play in your phone
4. 4. Click the Green start button at the bottom and wait for it to convert
5. 5. Go to My Documents folder in windows and open up My Videos and your video should be there.
Spanish version:
Si usted ya ha descargado el archivo FLV siga estos pasos:
1. Descargar e instalar un programa llamado RealPlayer SP aqu?:
2. Una vez instalado, abrir RealPlayer SP, a continuaci?n, haga clic en el archivo haga clic en Abrir, busque el archivo FLV y abierto , y pasa el rat?n sobre el v?deo que se est? reproduciendo y en el fondo usted ver? un bot?n que dice "Convertir"
3. Haga clic en Convertir en la parte inferior del video, una peque?a ventana emergente con un video en
la lista, en la parte inferior dir? convertir, haga clic en la lista desplegable a continuaci?n, seleccione bayas negro curva o incre?ble HTC, ambos formatos de archivo debe jugar en su tel?fono
4. Haga clic en el bot?n de inicio verde en el fondo y esperar a que se convierta
5. Ir a la carpeta Mis documentos en las ventanas y abrir Mis v?deos y el v?deo se debe
all?.
I have an HTC Tilt 8900 Smartphone, but I cannot access my phone because I forgot the password. How can I access my phone, if I forgot the password to unlock it?
you need to do a full software replacement ...... www.htc.com download the rom ..remove sim card and Micro sd if you have one ...connect to active sync and click on the file you downloaded then just follow the instructions
Enabling the wireless adapter on my Tilt?
i upload the phone recording software in htc p3400i
2answers
Cannot delete unwanted *.exe & *.acc files
google for "star unlocker assistant" this program will unlock the folder so it can be deleted.
good luck
How do i download GPRS settings on my HTc tilt 8900 from airtel
hi there!
I suggest that you should contact your Network Service Provider to provide you manually the GPRS settings or over-the-air settings. So that could get an accurate settings and you can enjoy using this services.
1helpful
2answers
Daunlond the New Softwares
download from www.america.htc.com/tiltupdate on your pc.for
6.1 windows mobile update.
Htc tilt
  1. Launch File Explorer... from the keyboard select Function key (Fn) and the key with the blue folder icon.
  2. Go to the appropriate folder
  3. Long Press the stylus to see a submenu with Delete option.
Htc tilt phone
You have to get the new driver update to fix this problem, I had it for a couple of times until I got the update, now I am looking to sync my phone with the new driver.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
