Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
My frigidaire stove made a loud pop noise and a flash under the glass top when we turned on the front left burner. Now that burner will not work anymore. What part needs replaced? Is it the coil or another electronic component in that area? Thank you in advance for your help
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
aborcass
  • 2651 Answers
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Posted on Mar 03, 2008
  • 2920 Answers
SOURCE: burner on glass stove top has turned black
replace the glass top with a new one
Posted on Dec 06, 2008
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The right front burner on my Mom's Frigidaire FEF316(I think, the # is 316232636) does not work. She heard a pop and saw a flash under the stove top near that burner when she turned it on. I switched the...
The recepticle that the burner ends plug into get worn and loose. This will cause arching and that may be what she saw. OR, there could be a wire loose under the stove top feeding the burner. Lift it up and give it a good inspection (with the breaker off). You may need to replace the burner recepticle.
Aug 01, 2009 | Frigidaire FEF316 Electric Kitchen Range
Loud pop when I was baking with the oven on Convection bake
Did you resolve the problem with your stove.
Mine just did the same thing.
Jun 22, 2009 | Electrolux Kitchen Ranges
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire gas range makes loud whirring sound when oven is set above 250
You don't give a lot of info here (like if the range was converted from natural to LP, or if the burners are OK, or if it is a self clean model and how the broil works, etc) and I can't guess all that, especially because a lot of people post under whatever model pops up when they enter a key word while posting a problem, but,..........
Any range that was professionally installed should have been tested for proper burner and oven operation by the installer before they left. Call the installer back and let them know you are not satisfied.
Nov 02, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
589 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
