Question about Canon PowerShot SD100 / IXUS II Digital Camera
I cannot take clear pictures but everything else seems fine
About a week ago it started and i have no idea why it wasn't dropped or harmed in any way.
the LCD screen is clear and i can still take movies and the play back is fine. when i try to take photos the LCD screen looks fine but then once i've taken the picture the image is all distorted with white hazy covering.
Did i hit a button or change a setting without realizing it or is it just busted?
  • ixusblur Nov 03, 2007
    I am having the same problem but with a pink/red hazy covering. Anyone know how to fix this?
  • Anonymous Jan 21, 2008
    Hi my Ixus II displays old images fine, takes movies fine but has developed a fault when taking new pictures. The 'live' images on the LCD screen appear OK but once the picture is taken and I switch to 'view', the picture is all pale and has white horizontal stripes at regular intervals across it.
    If I take the card out and view on a computer, they are the same!
    I took the battery out, pressed ther reset button, removed the backup battery too.No different.
    As the direct view (before one snaps a picture) and movie option only use low resolution, I had the idea to reduce the resolution of the camera to low. Still the fault persists. I took the SD card out and painted a black square with photoshop in the centre of one of the dud picuures. I then put the card back in the camera. Stripey all round like before but the square is OK.
    Is this a CCDfault or data transfer bus or internal buffer memory problem?
    Please help....Dave
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
88 chevy 2.5l, gets fuel will not start
An engine shut not backfire unless the timing is off, it has a burnt valve or an exhaust restriction. Since the crank sensor was the catalyst for the problem, I would again check it. It definately affects the timing for the fuel and spark
Sep 07, 2014 | Cars & Trucks
Headlight problems
n I've noticed that not all bulbs are the same and they have voltage drops causing one to burn out sooner. Replace both at the same time and if you can find a two pack that would be better.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Nov 09, 2013 | 2007 BMW 3 Series 328i
Milwaukee magnum 0234 drill stops working when hot
I feel you have gradually burnt the unit out. over time. I feel it's done. After a while it just will not turn at all.
Aug 11, 2012 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
I bought a Nikon D90 a few weeks ago. It worked
Your camera may be faulty. Or you might not be "in focus". The D90 in any of the auto modes won't take a picture if the 'in-focus indicator' isn't on. If that indicator is blinking, then it means that it is not able to focus on the subject. It's all in the user manual.
May 15, 2010 | Nikon D90 Digital Camera with 18-105mm...
It seems the picture is getting out of focus or not as clear. i've noticed it today, but it started a couple of weeks ago. any suggestions on how to get the picture clear/
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2010 | Sony KP-57WS500 57" Rear Projection...
Windows Explorer problem
You might try re-installing IE. Maybe a new installation will debug. It won't do any harm...
Aug 25, 2009 | Computers & Internet
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Canon PowerShot SD100 / IXUS II Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
