FixYa.com
Tags:
Intel Motherboard
No display but cpu fan is working condition (by 7 users)
posted by tika on Oct 24, 2007
when i power on of cpu but no display what can i do you tell me
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by parmu, posted on Feb 23, 2008
same problem problem......problem started after a surge in the flux box....please give me some solution who have already faced and solved the problem.....
Comment by Guest, posted on Feb 23, 2008
exactly same problem . the problem started after a surge in yhe flux box
Comment by Guest, posted on Dec 31, 2007
Got the same problem here. Cpu fan runs but no video. I tried unplugging all periferials and no luck. Tried different memory. I am not even getting a beep.
Comment by lord_phoenix, posted on Dec 20, 2007
Having the same problem, no display (CPU working tho)
Tried removing the RAM, the system beeps on power up.
Tried reseating the RAM ... no display.
Unplugged all drives (floppy, dvd, hdd) ... no display.
Tried different monitor (to check that the problem wasn't caused by my monitor) ... still no display.
Comment by Guest, posted on Dec 14, 2007
No Display, but CPU fan works, Tried replacing RAM modules. The BIOS error beeps 1-5-2 (only one cycle)
Solution #1
posted on Aug 27, 2008
Not Rated (0)
robin703
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I find a very good site for Intel Motherboard Solution. Try the site click here.
Please Rate me if this information helpful for u.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 05, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I have a similar problem with my Intel mother board D865GLC and it not unbooted and sometimes it will got a blue screen while it was luckily bootup successfully.
I tried to solve this problem in the following steps:
1) I cleaned all the dust on my motherboard, especially those resistors hided by the heat sink of the CPU.
(it worked normally again for several weeks and then the motherboard is not so stable, the system are sometimes halted and sometimes the blue screen jump out :-( )
2) Then, I tried to check all the components - RAM, CPU, FAN and Power supply, etc. They seems all OK! but the problems still.
3) I tried to open the case and check the temperature of the board and the problems still.
4) I reinstall the system, but the problem still :-(
5) I am going to give-up; but I think the problem may due to the memory related, because can't bootup with no beep sound and blue screen are the problem of memory.. So, I try again to remove all RAM and using a contact cleaner to clean the RAM slot and the gold contact. The PC work again!!!
Solution #3
posted on Feb 04, 2008
Not Rated (0)
joey64
Rank:Wiz Wiz
Rating: 80%, 177 votes
check the connection of your video card, this is the common problem of cpu's specially if you are moving from one place to another. try to uninstall the connector of your monitor to the video card. if you have an extra video card try to replace the existing then power on. loose connection of your video will give you a rapid beep sound. if you are using the on board vga you try to install a video card or try to tighten up the connector.
Can you Help with these Motherboards problems?
Intel Motherboard
Plugging in a USB port.
Trying to plug a USB port into... Answer This...
Intel Motherboard
BLACK SCREEN WITH POWER TO...
dell m170 laptop has a black... Answer This...
Intel Motherboard
mother all driver
hi iam ravi i am format my pc... Answer This...
Intel Motherboard
Multimedia Audio Controller...
hi.. I am running win 2003 ent... Answer This...
Intel Motherboard
Mic doesn't work with DG 965 RY
Hi, Were you ableto find a... Answer This...
6 Other Users Have The Same Problem - Continued
No Display, but the CPU fan works. Beeps of 1-5-2 (all short beeps) only once.
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
