Make sure to plug the USB adapter at the back of the of your computer. Try to use different USB port. Also try to plug the adapter to a different computer to check if the adapter is defective or not. Because it could only be your USB port
i had the same problem. the only way the computer recognizes the 760 is from a fresh re-boot. a few tricks from tech support. when shutting down, first disconnect, then power off modem from the VZW software. the next time you plug it in the computer then recognize the modum.
a different problem is the signal strength. my old 720 had a much stronger signal in the same location and a faster connect speed. any ideas?
Trouble setting up Zoom modem/router with PSP model 559OE. It never finds the ip address so I do a...
(More)
Trouble setting up Zoom modem/router with PSP model 559OE. It never finds the ip address so I do a manual setup and it still won`t work I could be entering the info wrong I know it work because my DS works with it
We purchased a D Llink router which we have installed but it does not communicate with the new...
(More)
We purchased a D Llink router which we have installed but it does not communicate with the new printer we got to go with it or the PS3
whenever i use cordless phone it zaps my wireless and i can't get router signal. This has just been...
(More)
whenever i use cordless phone it zaps my wireless and i can't get router signal. This has just been happening for the past month. Before that I never had problem using my cordless and laptop at the same time.
just overnight this problem occured out of the blue.My usr 8054 is still on and functioning i can...
(More)
just overnight this problem occured out of the blue.My usr 8054 is still on and functioning i can watch tv over he internet on tv via my box router is active can see it on wireless network list but cant get conected.Both my laptops cant get connected anymore the error msg is connection failed.I dont know what to do would apprecite yr help.Tried to turned it on/off nothing seems to work.
