Question about Cadence Z8000 Car Audio Amplifier
Amp staysin power safe mode
As soon as we power up the amp by its self it goes into to power safe mode. Tryed everything our tech knows and still can not get it out of power safe mode. Opened amp everything seems fine it is being installed into a alero chevy
    Problem Solver:
  • 8 Answers
Check your ground wire and put your setting on your amp to low HP LP FULL also check the radio wires
Posted on Jun 10, 2009
How do i get my amp out of protect mode? when everything is unhooked but the hot, ground, and rem wires, as soon as the amp comes on it goes n to protect mode how do i get it out
Check to make sure that there are no stray wires crossing into other inputs in the amp, if everything checks out OK then the problem is internal.
Oct 27, 2011 | Lanzar VIBE286 Car Audio Amplifier
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
My kicker kx1200 powers up fine but turns it self of an comes back any ideas to what it can be
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Kicker KX1200.1 Car Audio Amplifier
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
My alpine pdx 1.1000 amp cuts out, the sub cuts off and the amp goes in safe mode but it does it before it even gets loud, the sub is a 2000W rms sub, why dos the amp go in to safe mode, i cant turn the...
Power is rated at 1000x1 @ 4ohm.
How many voice-coils does your speaker have? If more then one, are the coils wired in series or parallel? How many ohms are the coils? If you actuate the cone with your hand, do you hear any "scraping" sounds?
Assuming everything above is within range and or tests good, the amplifier more then likely has at least one failed output transistor. a DMM would be needed to check for shorts.
Jun 24, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Dell D600
Sounds like a driver might have gone AWOL. Can you go into safe mode? Usually by pressing F8 after the Dell logo you will be prompted to go into safe mode.
Go insto safe mode and once inside restart the computer. This will repair anything that may have shutdown improperly.
If you can, also change the resolution to the least available, normally 800x600. Once you get back into the "normal" session, you can set it to your liking.
See if this works for you.
May 18, 2009 | Dell Latitude D600 Notebook
The amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Mar 27, 2009 | Car Audio & Video
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Cadence z1200 stays in Safe Mode!
If the subs are rmoved from the amp (wiring), does the amp still go into protection without them hooked up? If no, shorted sub, if it still des, unplug RCA's, does it still go into protection? Also check voltage. Make SURE you have greater than 12 volts AT THE AMP using amps ground to check the power AND remote wires. Hit me back wth an update.Those amps rock.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Sep 17, 2006 | Cadence Z8000 Car Audio Amplifier
Cadence Z8000 Car Audio Amplifier Logo
483 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
