Question about Canon NP 6050 Copier
E005 Hi, I'd like to know how to resolve this error. I have already reset the WEB counter and still having problem. Thanks a lot
  • vwbobby Nov 09, 2007
    I get the same Error 005. The copier was bumped into and the duplexer was bumped away from the main unit. It found a broken gear on the small tray on the right "Tray 1", it has 28 teeth on the gear that moves the tray up and down.
    I can't get the 2ND from the bottom tray open, it is jammed. Any help? I pulled most of the trays out and felt around. I can't find what is hanging up the tray from sliding out.....
    Thanks in advance!
    -Bobby
  • Canon Expert
  • 270 Answers
On this copier you have to reset the error code by getting into service mode, depressing *, 4, * , right arrow once to the ERROR screen and then depressing " OK ". Copier should momentarily turn itself off, then come back on again and all should be ready. I'm assuming that the WEB is installed properly with the supply roller coming up over the top and going back down the the take up roller. Good luck.
Posted on Nov 13, 2007
  • 77 Answers
Hello bud,easy problem just replace your fuser cleaning web,and reset the counter.
Posted on Oct 24, 2007
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
I have replaced le fusing cleaning WEB but the error code E005 is still displayed when I switch on the copier CANON ir400. What can I do to reset the error code. Thanks
You have to get into service mode and go to the counters and go to the web counter and reset it. Also, You may want to go to the Funcation mode and reset the error codes also. To lock the counters, turn the main power switch OFF then back ON.
Aug 30, 2010 | Canon imageRUNNER 400S Copier
I have a canon 6551 which is giving me an error E-005 turn switch off and on, but nothing happens. How to resolve?
The E005 error code means that the machine needs to have its Fixing Web replaced. After replacing the web, the error code will need to be reset. The part number for the Fixing Web is FY1-1046-000 . To reset the E005 code, you will need to access service mode by opening the front cover of the copier, insert a straightened paper clip into the small hole (located on the left, front side of the upper inner cover), press button with paper clip. Press the Additional Functions (*) button. A " $ " will appear in the display. Press *, 4, *, then you will need to navigate to web counter, select and then enter all 00000 to reset, press ok.
Jan 27, 2010 | Canon NP 6551 Black and White Copier
E005 - which part(s) to replace?
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
Nov 17, 2009 | Canon ImageRUNNER 330s Copier
I am getting error code e005 0100 how do i reset
E005 Error code details
  Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
 0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
Sep 04, 2009 | Canon CLC 1180 Copier
E005
Hi Malcom
Go in servicemode(use a long L&key to press the microswitch)
You will find the microswitch by openning the front cover and on the left upper part under the controll panel you will see a very small hole were you have to insert a long,thin L&key to press the microswitch.
If you have pressed the switch a "$" sign will apear on the screen.Press *6* and page to the web counter,press clear and then ok.
After this is done press *4* and page to error press ok and switch machine on and off.
That should do it
Jan 16, 2009 | Canon NP 6050 Copier
Error "E005" by Canon GP285
A E005 is the Cleaning Web has run out or the counter has reached it out count. You have to replace the cleaning web in the fixing unit. And reset the counter for the web. It is not good to just reset the counter because inf you run out of the cleaning web you may cause more damage to the fixing unit and thus coast you more money and time. It's best to call a repair person and ask them to bring a cleaning web ( maybe $65.00 -$75.00 plus labor) That's your best bet
Sep 09, 2008 | Canon imageRUNNER 210S Copier
Cannon NP6560
A E005 is the cleaning web counter. If you have replaced the cleaning you can reset the web counter in service mode under counters... The service switch is right next to the total meter in the front of the inside cover of the copier.... Once you press it you will see a little "$" sign shows and hit the "*" "6""*" and courser down the the web counter. You have to hold down the Clear botton and the hit the service switch to reset the counter back to zero... Good Luck
Apr 28, 2008 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon NP 6050 Copier Logo
148 people viewed this question
old marine
old marine
