Question about HP Pavilion dv6000z Notebook
HAVE 2 DESKTOPS IS THERE FITTING TO RUN BOTH OFF 1 MONITOR
HAVE 2 DESKTOPS IS THERE SIMPLE FITTING TO CONNECT BOTH MACHINES TO ONE MONITOR.
WOULD BE USING ONE MACHINE AT A TME
E MACHINE XP(32BIT) & HP PAVILION (64BIT) SAVE MANUAL DISCONECTING FROM REAR OF EACH DESK TOP
  • focus09 Jun 04, 2009
    THANKS ALSTECH & JTOAST
    ADVISE MOST HELPFULL
    PHILBY!!
  • 105 Answers
The device you are looking for is called a kvm switch (Keyboard video and mouse are plugged into the unit and them you only need one montor /keyboard /mouse the come in varying configurations ie 2 pc 4 pc 8pc or 16 pc the two and for port versions are cheap on the inet just do a search for kvm and then select the type you require what type of keayboard connection your keyboard / mouse uses ie ps2 smaall 7 pin round plug or usb Regards Al "alstech
Posted on Jun 03, 2009
  • 86 Answers
Yes. Its called a KVM (Keyboard video and Mouse) switch. it will allow you to use a single keyboard, mouse, monitor for multiple computers.
They can be found at most any major electronics store/website and, depending on how many machine you want to connect, can be very cheap or fairly expensive.
Connect dual monitors
According to HP, You can run 2 monitors on this machine. the problem is that one of them has to be a VGA and the other one must be a DisplayPort monitor. The display port connector looks similar to an HDMI port but is not the same. There are adapters that claim to convert DisplayPort to VGA but I've had mixed results trying to use them. I KNOW they don't work on some Lenovo monitors. You can find your specs here:
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01549447&DocLang=en&docLocale=en_US&jumpid=reg_r1002_usen_c-001_title_r0002
the monitors should be connected and then the machine powered up. you should be able to right click on the desktop and go to properties and configure the monitors
Feb 12, 2014 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
Run multiple monitors
the Matrox Parhelia PCI allows 3 monitors, it also works with pci (of course)
i'm not sure about the price
Dec 15, 2007 | HP Pavilion Media Center TV m7360n...
Some icons on desktop not fitting on screen
1. Hold 'Windows + X'
2. Click 'Disconnect display' or if not connected 'Connect Display'
3. Select 'Projector only'
N.B: This is for windows 7
Jan 05, 2013 | Google Chrome
Can i use a secondary display that will extend the desktop, rather than just duplicate it, running this machine: emachine ET1641-02w. BIOS Version/Date American Megatrends Inc. V1.02E, 9/18/2008 Adapter...
Connect your second monitor On the desktop right click and select personalize. Then click on DISPLAY SETTINGS you should see Numbers 1 and 2. Now click on the monitor with the 2 display and then check "EXTEND THE DESKTOP ONTO THIS MONITOR" Hope this helps. PLEASE RATE
Jul 04, 2011 | Computers & Internet
No signal from desktop to monitor
Hi thanks for asking,the reason you are not having any signal is because of one of the following: your monitor may not be connected properly,please check all connections for your monitor.If you still have the problem this mean the video card in your computer is bad and you need to buy a new one of the same kind and put it in your computer.There are there are two types of video cards (1) AGP which is use by older computers and fit in a short brown slot on the motherboard and (2) PCIe which is use in new version computers. I advise you open your computer and look for the slot on the motherboard it is separate from the other slots and if its brown this mean you need a video card for AGP slot.
Jun 13, 2010 | E-Machines eMachines Desktop PC
Can a compaq fs7600 connect to a wireless internet or is it too old?
The monitor is just a display device, it how fast your PC is. I can easily surf the web for simple email and browsing the net with P3 1.GHz machine running XP PRO. You will need WIFI card for the PC.
Apr 20, 2010 | HP Compaq FS7600 17" CRT Monitor
Has a cord that has the same type of connection on both ends
Look on the back of the emachine, there should be a blue connector with 15 holes in it. Thats the VGA connector and thats where the other end of that cable goes.
May 31, 2009 | E-Machines eMachines Desktop PC
Researching before buying
You can absolutely handle any screen you want. Just make sure if its an older computer to find a VGA connection on the new monitor and that will work out perfectly fine :).
Mar 23, 2009 | Dell Dimension 2300 PC Desktop
Emachine
Hi foxy37, so what you mean is that you have no display on your monitor? I can only ask you to check a few basic things & than I'll need you to post the model number for your e-machine so I can suggest other information.
1. First check that the monitor cable is securely connected at both ends (monitor & PC), & that the monitor's power cord is plugged in & is turned on.
2. The last time you recall running the PC did you or anyone else install any software? Was any one inside the PC? Did the PC run correctly? Now I'll need to know what model your e-machine is, so I can go here & check what you may need to do to check the PC.
Click this link. http://www.emachines.com/support/product_support.html?cat=Desktops
Mike
Mar 30, 2008 | E-Machines eMachines Desktop PC
AGP slot
try a 3 way monitor vga switch 1 imput and 3 outputs to your monitors
Dec 14, 2007 | HP Pavilion Media Center TV m7360n...
HP Pavilion dv6000z Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
