Crystal s-2005 hello , i have an hold washing machine ,the issue is that i can not find the filter in order to clean it , is it possible this model don't have a filter ? thanks.
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
mikedurland
  • 481 Answers
SOURCE: Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Posted on Aug 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Posted on Dec 01, 2008
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
MNTECH
  • 1543 Answers
SOURCE: I need to order another filter assembly for my Lg
383EER2001A is the filter and cap assembly you are looking for.
Posted on May 18, 2009
How to clean filter
You need to post the make and model number. But if the filter is sticking then you may have to remove the hoses and clamps and screws that hold the housing and take the whole thing out. I have seen some serious issues with those and bobby pins causing jams etc.
Dec 18, 2015 | Washing Machines
My Russell Hobbs RH1042 5Kg White Washing Machine won't intake softener when I put a wash on, it just stays in the drawer. It is brand new so won't need cleaning out? Can anyone help?
have done all the cleaning with toothbrush ran the machine on a boil wash frequently on empty bought all the washing machine cleaners used white vinegar soda crystals all to no avail not taking fabric conditioner and the filter at the bottom of the machine after each wash filling up with water at my wits end any help please
Aug 17, 2012 | Washing Machines
Not getting water to washing machine hot or cold
Hello, Thank You for using FixYa. I will be helping you today.We see allot of issues with this. If the water is on and filters where hose is hooked up are not blocked then you will have to replace the pressure switch temp selector switch. It is a combo switch. When you look it up by your model number order the temperature switch.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washing machine is doing everything except spinning the spin cycle
This is most likely caused by the drain motor. Pull the filter out of the lower access panel. clean the filter and it should fix the issue
Apr 03, 2011 | Washing Machines
HOTPOINT AQUARIUS WF546 My washing started to smell so I removed the inlet filter to the pump, removed debris and cleaned the filter. Once refitted I then switched the machine back on. Now it starts a wash...
Hi, i had the same problem with this washing machine, i cleaned out the filter as you have already done & i also put soda crystals & white vinegar in the drum & washed on the hottest cycle,this cleans out all the build up. Theres no harm in trying it, hope it works for you too.
Mar 13, 2011 | Washing Machines
WD-J1255C SAMSUNG washing machine is washing but doesn't drain and spin. what could be the problem and possible solution? thanks
Best guess is a blocked filter. If the filter blocks, the machine won't drain and if it isn't drained, then the spin cycle won't kick in.
I'm not familiar with your machine, but chances are that there is a filter door at the bottom of the machine at the front that should be opened, the filter removed and cleaned.
I'm presuming that your machine is half full of water at the moment, so in order to remove the filter and clean it at this stage, you would do well to unplug the machine from the mains and then tip it backwards 45 degrees so that the water doesn't escape when you remove the filter! Best thing is to tip it back onto a chai if you are doing this alone, so the chair can take the weight while you undo the filter.
Now.... IF you are unlucly and have no filter in the front then go take a look underneath while it is tipped back. There will be a rubber hose that leads down to a debris trap, then on to the pump. You will need to unclip the spring clamp that holds this in place in order to get access to the debris inside. PROBLEM here: you are unlikely to do this without getting very wet!
I would suggest in this case, repeatedly putting the machine onto spin cycles, it will attempt to drain the water and slowly, bit by bit it will get the water out. Once it has drained (after attempting to put it through a dozen spin cycles probably) you should then be able to access the filter/debris without getting too wet!
If you do have a filter that is accessible through the small front door I described, I would suggest that you make it a monthly task to remove and clean it at the end of a wash cycle to avoid this issue in the future.
Feb 28, 2011 | Washing Machines
Crystal-like substance
It sounds like your water system might need some filter housings installed?-- are there any filter housings in any of your water systems?-- If so, what are they accumulating-- what do you find, when you change filters.
Write back what you are finding.. If you have no filters, then let's install either ONE on your common cold water supply to the house-- or start with two at your washing machine. Which would be easier?- Write back-- Mack Baxter
Nov 02, 2017 | GE WBSR3140DW Top Load Washer
Hello. I think this is the model..it looks
Well Bridie no there is no lint filter inside your washer the only possible explanation, is either old lint and particles are coming from previous washes. or you have just washed something recently that may have come apart such as a pillow, a mat with a rubber backing, or even a blanket with any sort of fiber material in it. It is more than likely that much of the lint that goes through your machine is unseen and can cause pump issues. hope this helps.
Thanks
Oct 12, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
