Question about Toshiba Satellite A205-S4587 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
  • 54 Answers
Yes, max memory is 2GB per slot for a total of 4GB.
http://www.computermemoryoutlet.com/Toshiba-Satellite-A205%5ES4577-memory.htm
Posted on Jun 03, 2009
  • 479 Answers
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
I have a mboard of ASROCK M266A but idont know If what type of RAM that im going to use for my DDR socket?
Your motherboard support 2x DDR, DDR 266/200 non-ecc RAM. It can support up to 2GB of memory.
You might not be able to buy it brand new on this type of memory, as this model is deemed obsolete.
Hope this helps.
Apr 18, 2011 | Asrock M266A Motherboard
I have a Pentium 4, 2.66Ghz processor with 848P-A7 motherboard. I purchased hynix 2GB DDR400 SDRAM PC3200(2X 1GB RAM KIT) to replace my 512MB DDR. Why does it not work ? Spec Says that it supports...
Hi dont know why new RAM dont work, may be faulty. Go to www.crucialmemory.com
Let them scan your computer and they will tell you what memory slots you have and what memory you should be able to use
Jan 23, 2011 | EliteGroup 848P-A7 Motherboard
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
I purchased 2x 2GB DDR2 rams for my laptop (toshiba A205-s5823) but only one will work in the slots with a 1 GB in addition. I've tried every variation in both the slots. What am I doing wrong?
Your laptop can only accommodate a maximum of 2GB of physical memory. If you are running Windows Vista, you can get a little extra memory by using the "ReadyBoost" feature that is built into the OS. I have done that in the past and it works well for me.
Here's a link to Kingston's (a good memory mfg) memory guide for your model laptop:
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=43561&mfr=Toshiba&model=Satellite+A205&search_type=&root=us&LinkBack=&Sys=43561-Toshiba-Satellite+A205-S5823&distributor=0&submit1=Search
Let me know if that helps!
Mar 11, 2009 | Toshiba Satellite A205-S5823 Notebook
Toshiba Laptop A205-S4577 won't start up
If the battery is removed, it should still start up with the charger connected. A lot of laptops develope problems with the jack where the power supply plugs in, from constantly plugging & unplugging the charger. The jack in the back of the computer is probably bad.
Jan 15, 2009 | Toshiba A205-S4577 Notebook
Toshiba A205-S4577
Check your power settings. You might have it set to shut off after a certain time of non-use.
Sep 22, 2008 | Toshiba A205-S4577 Notebook
Toshiba A205 not seeing 2 gigs installed
you have a bad brand ram.Contect your dealer
Feb 23, 2008 | Toshiba A205-S4577 Notebook
About drivers
Go to pcsupport.toshiba.com, Downloads > select your unit > Download again.
Oct 15, 2007 | Toshiba A205-S4577 Notebook
Toshiba Satellite A205-S4587 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
