Question about Planar PL2010M 20" Flat Panel LCD Monitor
Monitor flashing and blinking. help! - Planar PL2010M 20" Flat Panel LCD Monitor
  • tsmall Dec 19, 2007
    Monitor is flashing and blinking and sometimes goes completely black. Please help!!!
Inverter board
Posted on Aug 22, 2008
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Mar 18, 2015 | Planar Computers & Internet
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
Monitor blinks constantly
If video flickers, I would open it up and check for broken capacitors on the power supply PCB.
This tutorial will help...
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jan 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Monitor power light is blinking .but monitor is not displaying anything after 4 hr monitor blinking light is become slow and when restart the monitor is displaying after 4 hr please help me i have a 20.1...
If there is a flashing led on front of the monitor, that indicates a fault condition.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
Regards
Oct 15, 2008 | Westinghouse LTV20V2 20 in. EDTV-Ready LCD...
LCD blinking on and off continually
If it flashes ON and OFF when simultaneously unplugged from both power and the computer then it's trying to communicate with you. Mine flashes code to me. It tells me what to do. Last night it told me to get it $5,000,000 in unmarked bills. Seriously, turn the monitor on without connecting it to a computer. If it flashes ON and OFF continously, then you have either a bad monitor or a bad AC/DC power adapter/brick (you know, the rectangular black corded adapter you plug into the wall outlet). If it only flashes ON and OFF when connected to a computer, try the monitor on another computer. If the monitor is 3-4 years old, it may be time to replace it since a replacement AC/DC adapter might be very hard to find. Let me know what you find out, if you need more help. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Liquid Video E17LCD1 17" Flat Panel LCD...
Planar PL2010M 20" Flat Panel LCD Monitor Logo
131 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
