Eiki LC X999 Multimedia Projector Logo
A
Anonymous Posted on Jan 28, 2014
Lc-x1100 convergence service menu
Eiki LC X1100 - the unit is loosing all power [no standby leds] when switching on after being off for 5 minutes or more. I've found that if power is disconnected and Reset switch is engaged it will come...
in primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
Eiki lc x1100 multimedia projector lyrics are "shadowed" with multicolors
screen ,the color is ghost,
LCD panel is broken.you need a new one USD120
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
My Eiki lc-x1100 is not displaying very bright. I bought is used from a university and it only has about 900 hrs. on the present bulb. Is there something else that would make it dim? Don't want to...
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
1helpful
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
2helpful
How to install my lexmark x1100 all in one printer without cd
First thing you need to do is uninstall the current software and printer.
Then go to: X1100 Series Driver
Select your operating system...Vista...from the drop down menu.
The next page has the link to download the driver. (It should be cjrX1100EN.exe. Click on "Download Now".
When you begin the download and the download window appears, select "Save" and direct the download to save to your desktop.
After the download is complete, close all the windows, or other programs.
Make sure your printer is ON but also that the USB cable is DISCONNECTED. Double-click the file on your desktop that you downloaded. When prompted by the software, connect your USB cable.
That should do it. If you run into any problems, just comment back.
Thanks for using Fixya.
1helpful
Eiki LC-X1100 Powers "off" after 10-15 minutes
even if the filters are clean, you will still need to blow the dust out of it with canned air. may be overheating. otherwise, sorry to say, it is the ballast.
Top Eiki Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
