Question about Kodak EasyShare DX7440 Digital Camera
I have a Kodak dx4770 camera and it will turn on and then off immediately and not work. I tried 3 batteries and they work in another Kodak camera.
    President:
  • 2,761 Answers
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Posted on Aug 09, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Aug 15, 2009
    Remove the batteries and clean the battery contacts inside the camera
    with a soft cloth (a heavy buildup on the contacts may require cleaning
    with a fine wire brush, steel wool, or sandpaper). Remove any residue
    that the cleaning leaves in the camera, and then reinstall the
    batteries. This clears most power-on problems, but if yours persists,
    check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/r...
  • Bill Buchsbaum
    Bill Buchsbaum Aug 16, 2009
    This problem is frequently due to corroded battery terminals inside the
    camera. Remove the batteries and wipe the terminals with a soft cloth
    (heavy corrosion may require a fine wire brush, steel wool, or
    sandpaper). Remove any residue left in the camera by the cleaning.
    Clean the terminals on the batteries in the same manner, and then
    replace them in the camera. This cures most problems, but if it
    doesn't work for you, check the Kodak troubleshooting guide at:
    It uses a simple Q&A format to diagnose problems and propose solutions.
In this case, I think the problem is with the orange battery clip inside, or the two battery spacers inside the compartment, after trying to "remove the corrosion" from contacts and bumping around the two battery hold-down spacers, afterwards the clip didn't work, and the camera would spontaneously re-start if I touched it when off.
Posted on Apr 28, 2012
Camera goes on and off immediately
Even though they are charged thay might have a fault. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 26, 2010 | Kodak EasyShare M873 Digital Camera
The batteries always seem to drain shortly after putting them into the camera, no matter what type or brand of battery I use. Help!!!
?? Drain as in leaking. If the camera makes the batteries leak you should contact KODAK immediately and they will make a HSE case for you. Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If you mean the camera is drinking batteries try these steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 20, 2010 | Kodak EasyShare C633 Digital Camera
When I turn the camera on, it immediately turns off. I have changed the batteries twice already. What's causing this?
I don't know the exact fault of this problem, but try these steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 19, 2010 | Kodak EasyShare C913 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
I have brand new lithium batteries installed & when i turn camera on, it immediately shuts off. camera is only 1 year old
I have the same problem... cleaning the contacts does not work. I'm using NiMH 2450 mAmp batteries, brand new, and I get a low battery indicator immediately. Camera shuts off unexpectedly. A short search online indicates that HUNDREDS of people are having the same problem. Kodak help not very helpful. I'm ready to buy something else!
Dec 11, 2009 | Kodak EasyShare Z712 Digital Camera
My camera turns off right after i turn it on. it
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
Unfortunantly KODAK do no longer repair this model. They offer a Trade up option where you for 25-30% cheaper than the listed price can exchange the camera to any newer model provided KODAK has the model in stock.
Contact KODAK:
Nov 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
My camera lense won't close even when i turn it off & on. i have tried to turn it off and on the screen only goes on & immediately turns off. the green light in the corner flashes so i know that...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare V1003 Digital Camera
When I turn my digital camera on it turns off immediately. Why?
Try connecting your camera to the computer while the battery is out, i know that your camera support USB charging, then turn on the camera while conencted to the computer, if the camera turn on it means the battery is no longer working. And if still wont turn on, maybe there something wrong with the camera. Call kodak for assistance. or visit www.kodak.com/go/itg for online troubleshooting.
Aug 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera lens turns on, then back off immediately
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 05, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak C533 turns on briefly but then turns right back off.
what type of battery are you using?try to use lithium or rechargeable batteries. Alkaline batteries can cause power issues. If you are using a memory card, try taking it off and turn camera on without the memory card. if is still does not power on, camera needs repair. you can set up repair for your Kodak camera at www.kodak.com/go/itg
Dec 05, 2008 | Kodak EasyShare C533 Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
184 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
