Question about Hunter 52" Ceiling Fan With Light And Remote Control
My hunter ceiling fan does not rotate very fast when on high. It looks like it's on medium speed. Did I hook it up wrong?
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Posted on Jun 19, 2009
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 4 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
It's a 3-speed ceiling fan that's for sure. I think the same a fixer1950 already said...
This page about <a href=http://www.ceiling-fan-wizard.com/hunter-ceiling-fans.html>hunter ceiling fans</a> might be interesting...
Posted on Oct 09, 2009
  • 57 Answers
SOURCE: my hunter remote control ceiling fan doesn't go
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
Posted on May 16, 2010
I replaced the 3 speed fan switch on my Hunter 21834 ceiling fan/light. The fan only has 1 speed (fast). What did I do wrong? I tagged each wire to match up, but now only one speed.
What was the original reason why you changed the switch? Sounds like you got the hot wire and high speed wire swapped. The hot wire coming from the upper part of the fan should go to 'L' and then the three other wires going down to the little black boxes for the speeds should go to the corresponding 1,2,3 on the switch.
Sep 05, 2011 | Hunter 52" Ceiling Fan With Light
Hunter 23852,L-black to red-hurricane speed,black to yellow-almost hurricane,black to gray-very slow,hardy moves air,installed westinghouse 6A125vac switch,same speeds,how can i get a comfortable medium...
Howdy,
Sounds like a good ol' American made Hunter Original to me. BEST and most powerful residential ceiling fan (high quality) ever made. The RPM spec is 200-160-50 for the respective speeds, moving 10,500 CFM on high speed. Most ceiling fans barely crack 5,000 CFM. they were built for Brute Force Air Movement and they really don't do well for small spaces. The best solution I have for you is if you have a Wall switch for this fan, to install a Hunter Original Wall control or remote control. http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=hunter+original+control&_sacat=See-All-Categories
Both controls will lower the Medium speed to about 100-110 rpm, which should be much more comfortable for you.
Because the Hunter Original (I know your fan is an American made unit by your wire colors) draws more current than other fans, the Original controls are the only controls that are designed to work with your fan. Other controls do not have the current capacity for the Original motor.
Also, are you aware your fan uses oil?
Aug 22, 2010 | Hunter 23852 Classic Original Ceiling Fan
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
Fan works on high and low ok but in medium it runs at low speed.
Sounds like the speed control switch has been replaced recently, or one of the capacitors in the black brick in the switch housing has failed. Most modern fans use a double capacitor for medium and low. High is wired straight across the run capactor (which is usually 2 wire by itself, or all three capacitors may be in one big black brick)
The symptoms you describe suggest that the speed capacitor has failed. Typically they are 5+5MFD, or two in one case On Medium both 5MFD capacitors are activated, but on low only one is activated. The capacitors serve as a "choke" that limits the amount of current getting to the motor (not voltage, but amperage)
Find out the manufacturer of the fan and if it is Hunter, their number is 1-901-745-9222. Tell them the model# of your fan and they shall get you hooked up with a new cap.
Jun 09, 2010 | Hunter 20485 The Wellesley Taupe Ceiling...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Jun 28, 2006 | Hunter 20516 The Savoy® White Ceiling...
Dryers Logo
2,495 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
