Question about GE WJSR2070B Top Load Washer
Water wont stop when i blow into tube. Just bought a new water level switch and installed it. Still overfilling.
Happened to us, flooded our garage. It's a design flaw. Pry open the front panel, the left side of the barrel you'll see a white box with a clear hose. Open control panel, far left is the water fill switch, there is the other end of the clear tube. Pull both ends, plug one end with your finger, and blow into the other end. Chances are there is a cut in the hose. replace it, everything should be fine. The original hose runs through a metal hole, shakeing of the machine saws the hose. Just a matter of time with these
Posted on Jul 17, 2009
The air tube coming off the side of the drum was clogged. I cut off about 4 inches of tubing and reattatched it. The sensor then picked up how much water was in the drum and functioned perfectly. I had a lady tell me I needed an $88 timer. But I found that even with a new water level switch if the tube has a loose fit or hole or is clogged the WLS wont function. Check the $4.50 tube before you buy a $88 dollar timer that has nothing to do with it. I read that here somewhere. Where ever it was thanks!
Posted on Jun 04, 2009
My washing machine does not take water in, I fixed a broken wire and I changed the water inlet pump it's still not working, the motor jumps twice and stop.
check ur water pressure switch and ur water inlet valve always test it before buying new water pump?
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
By the way my advice is free cuz God is good!
May 15, 2015 | Washing Machines
Error message 4E witch is no water,. but water is overfilling ?
Washer fills with water and overflows:
Machine filled with water then stopped working
Apr 07, 2015 | Washing Machines
Frigidaire washer mod#fws223rfs0 overfills
Feb 09, 2014 | Frigidaire Washing Machines
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
The air pressure line fills with water sometimes and causes the washer to overfill and the water just continues to run all over the floor
Remove the line from the switch and blow it out. Make sure that tubing is going down the little channel with the wiring harness so it wont get pinched. Re connect the tube tight to the water level switch and pump out the water before retry. I have repair photos HERE
Feb 27, 2010 | Whirlpool WTW5800SW
Kenmore 70 series , overfill water dose not stop at set fill levels
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 16, 2010 | Washing Machines
The washing machine will overflow, flooding water onto the floor. Flooding has happened 8 times, and it attempted to do it about another 5 times (I stand there and watch it and turn off the water supplies...
ive included a solution to a similar problem that i solved earlier this week, i hope you find this helpfull...
I am assuming this is a top load washing machine.... the load size selector button has a hose attached to the back of it. This hose goes down to an overflow box mounted to the side of the tub. This tube often gets clogged and the machine cannot tell where the water level is. 1) dissconnect the tube from the level selector switch and ( w/it unplugged ) attach another tube to it and blow into it. you should hear a clicking sound. this means your level selector switch is functioning properly. if it does not click then it needs to be replaced. 2) dissconnect the tube from the level selector switch and ( w/it unplugged ) blow into the tube and you should hear air going into the tub, ( this is best performed with water in the tub ( bubbles ) )....hope this helps
Asker's Testimonial " Thanks rdrsp. When I took the control panel off, I found that the tube had fallen off the control valve. I put it back on with a band clamp. " - bill_marv460 "
Oct 22, 2009 | GE WVSR1060A Top Load Washer
Does not stop filling with water
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
GE WJSR2070B Top Load Washer Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
