Question about Brother DCP 7010 Multifunction Laser Copier
Black spots and lines on papper
Black spots on papper while printer prints, copyprint is not clear, full of black line I mean extra powder on copyprint.
  • the kowalski
    the kowalski May 11, 2010
    Do the spots/dots repeat themselves vertically over the paper, how far apart are them if they do?
    Also, the lines, are they vertical or horizontal?
  • stephanie hulsey
    stephanie hulsey May 05, 2014
    vertical lines and they repeat a inch or so apart in rows
    President:
  • Brother Master
  • 990 Answers
Hello sir; Only thing you need to do is change a drum cartridge.
Posted on Jun 03, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
Canon i865 - black print is blurred/fuzzy on every 3rd line. Have done clean, deep clean, changed both 3 and 6 cartridges. No problems until recently. Beautiful full colour photographs clear and sharp,...
Your printhead has burned out nozzles, the black is the most used and first to go. It switches nozzles during printing for even wear, that's why every few lines you get bad spots.You need a new printhead.
Aug 07, 2009 | Office Equipment & Supplies
Full of black lines on copyprint
it is the problem your copier toner or charger. cherger ir dirty clean it then solve your problem
you install your old cartridge then you quary it
Jul 20, 2009 | Brother DCP 7010 Multifunction Laser...
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
The printer is printing lines across each page (usually one of each toner color, sometimes only black)
the toner cartridge is near to empty so the powder collected on the wastage side is getting leaked when ever you give a printout and that leaked powder creates a line on the paper. or there is a dust collected in the lower area of the printer by the leaked tonner. replace the cartridges or get refilled it properly.to make this problem clear.
Nov 17, 2008 | HP Office Equipment & Supplies
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Brother DCP 7010 Multifunction Laser Copier Logo
448 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
