Question about Gateway E-2000 PC Desktop
I am trying to find network drivers for the
I am trying to find and install network drivers for the Gateway E-2000 but cant find them anywhere on the gateway site do guys know know where to find them?
  • 479 Answers
please check on
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=10597&os=10406&type=10096
Posted on Jun 03, 2009
Need lan driver for gateway 300 se
You will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a Red X or a yellow Exclamation or Question mark ! ? you will need to update or install the driver or it could be firewalled. If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers Make sure you Ethernet/internet is enabled in bios Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) usually the Delete or F2 key press and hold that key to enter bios using arrow keys scroll to intergrated peripherals. Look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press ENTER make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled. http://download.cnet.com/802-11b-g-atheros/3000-2112_4-162108.html wireless lan http://download.cnet.com/realtek-rtl-gigabit-and/3000-2112_4-10278840.html 2000/XP/XP 64-bit. http://download.cnet.com/3dp-net/3000-2112_4-10915115.html Provide integrated driver installer that supports many model of Ethernet card if these drivers are not right http://download.cnet.com/2000-20_4.html just type in what you want or need be specific you might have to try a few times to get it right IE: Motherboard name lan drivers.
Place a tick in either windows software or the all software box. Hope this helps.
Jan 15, 2013 | Gateway 300 C PC Desktop
I have a gateway m-6750 notebook that i recently upgraded to win7 ultimate. for some reason my wireless adapter is no longer recognized and i cant find it anywhere
Hi
are y ou on your own laptop now
can you get onto the internet using a ethernet wire from your laptop into your router
if so have you tried all the windows updates
this may find and update the wireless driver for you
you could also try to un install it from your device manager
then re start the laptop
windows may on start up re install it correctly for you
have you looked on the official website for a windows 7 wireless driver
or you could look on the realtek website they may have a wireless driver for you
many thanks
Aug 19, 2011 | Gateway M-6750 PC Notebook
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
I reinstalled winxp sp3 on a gateway 450 rog. I was able to install all the drivers except the network controller and it also won't recognize the wireless adapter, any thoughts or ideas?
I had the same problem.
The "Network Controller" in my case had to do with the wireless network driver on my 450ROG.
None of the drivers that are available for 450ROG on the Gateway Support site worked correctly.
Here's what I did to solve the problem:
1. Flip the computer over. 2. On the back, you may see a little module that says "Fitted with Intel WM3B2100 802.11b". That's the built-in wireless network card (had no idea this computer had one, I inherited it). 3. Go to the Intel support site:http://downloadcenter.intel.com/ 4. Do a search for the "WM3B2100" driver. 5. Download and install the driver.
Fixed it for me!
Full info about the Gateway 450ROG is available at: http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353sp66.shtml This helped get me on the right track.
Oct 17, 2010 | Gateway 450ROG Notebook
I have an E-2000 Gateway, and the audio drivers are not anywhere on the internet, I have tried using E-2100, but these do not work my Bios is, RG84510A.15A.0037.P15, which does not match the SoundMax...
Go to Gateway web site. Put in serial number. Once drivers appear... download the one's you need. Run them. They will extract to your C drive cabs folder. go to the device manager to update the device you need. Do not let Windows search. Do a manual search and browse to the cab folder with your device driver exe in it (ex.952183). Click next to install.
Jan 15, 2010 | Gateway E-2000 Deluxe PC Desktop
Dell gateway dimension desktop 2600
You can install driver from following likn.
Download your network adapter driver then install in your computer.
Select your computer model from this link then downlaod network adapter driver.
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Then set ip addreses as your router settings then you can access internet .
Aug 01, 2009 | ZT Group CISNET A7022 PC Desktop
Not able to go online
If you have access to another computer you can go to the gateway site, download and burn the programs you need on cd or flash drive. Then install the flashdrive or cd into the laptop. To find out what programs you need to install on the gateway, go to the control panel>administrative tools>computer management>device manager.
Nov 06, 2008 | Gateway 7330GZ Notebook
Need drivers
Hi dj,
Just to clarify, exactly what drivers do you need. Hardware, software, installed devices etc... I will be more than happy to help you once this info is made available.
Respectfully,
anaanymous
Oct 14, 2008 | Gateway MX6440 (6585) PC Notebook
Sound Driver
Did you ask GATEWAY? Is it on board sound? Has the motherboard been replaced? Did you look on the Gateway site for your computer to get the driver for your O.S.?
Here is the link.
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4093nv.shtml
Apr 18, 2008 | Gateway 7405GX Notebook
Computers & Internet Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
