E machines h 5038
One of the worst computers ever.
it freezes by it self. some times for ten or 15 minutes.
the hing is that u hear the fan stops and thats it ;it is frozen
any help in this issue,
i bought norton anti virus but was useless for this issue
thanks
    Scholar:
  • 84 Answers
I had found one continuous problem with the E machine. The CPU fan. Take the cover off. Turn on the system. Is the cpu fan running or very noisey???. I find that the fan as most others collect a lot of dust. You will have to either vacumn or blow the dust & dirt out to free the fan so it spins normally. If the fan has stopped or stops and starts, replace it that may be the reason for the freeze up due to the cpu chip becoming overheated. Now if you are talking about the other fan. The power supply fan stopping and starting the system would shut down when that happens. That would be another issue.
Posted on Oct 24, 2007
I have the same problem it frezzes and then released.
i installed another memory but it still do the same.
now i have another problem :my screen places the message"the monitor going to sleep" then the omputer restarts
the worst computers ever EMACHINES 5038
if any body have asolution please help
Posted on Jan 21, 2008
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
How i can stop the fan and open the (locked) door (error F93)model Frigidaire CGEB27Z7HB
Hello Yves Trottier, thank you for your post!
I understand that your Frigidaire range is displaying the error code "F93". Typically, "F93" stands for maximum over door unlock time exceeded. This could be a potential issue with EOC (Electronic Oven Control), motor door latch assembly, or fan motor. I would recommend performing a reset on your range which consists of you disconnecting power from the range for approximately ten minutes. If you continue to experience such issues I would suggest consulting with a professional technician for proper diagnosis and repair. Hope this information is helpful. -Matt
Dec 06, 2014 | Frigidaire Kitchen Ranges
I have a Goodman a/c unit. Fan stopped shut off
replace the motor the bearing has seized up.
Aug 27, 2014 | Heating & Cooling
Imac freezes up
This sounds like overheating.. if the fan on your processor has failed you will get some time when you can use the pc and then it stops. Turning off for 15 minutes and then back on again gives you a little more time.
Solution.. check cooling fins are clear of dust and the fan is running freely, lack of cool airflow is the usual cause. if there is no dust and the fan is running then it is possible that the processor is suffering from failing ram.. try replacing your ram..
good luck.
Mar 30, 2017 | Cell Phones
Makes ice for 3 cycles then stops running.Can turn off then on again to make more ice for a couple more cycles.
check the cycle time for a batch of ice. should take around 15 minutes to freeze and then you will hear the harvest cycle kick in. If the harvest cycle takes 3 minutes or more that is your problem. You will need to get a hold of NICKEL SAFE ICE MACHINE CLEANER. DO NOT use CLR or any kind of cleaner other than NICKEL SAFE ICE MACHINE CLEANER. If the ice doesn't fall off of the plate in about 90 seconds either the plate is dirty or the nickel plating has come off. There is a failsafe shut down if the unit takes more than 60 minutes to freeze or more than 3 minutes to harvest 3 consecutive times. The cleaning instructions should be inside of one of the covers. If not it's available online.
Aug 15, 2013 | Manitowoc QY-0214A Self Contained Ice...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I am running Wxp on my Acer L100. After about 15
first things first pls check if the cpu fan is seated properly.
if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
Jan 11, 2010 | Acer Aspire L100 PC Desktop
Gateway GT4010 will not start most of the time the fan just runs.
Oopen cpu cabinet and then check wehn u power give to it led on mother bord is flashing or not?
If flasshing then your motherbord get power.
Then reattch all connection to mother bord.
Pull cmos cell for 15 minutes from mother bord also change cmos cell if it has low volt or it is old.
Then also cg\heckl your smps box is working properly.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Computers & Internet Logo
174 people viewed this question
Alun Cox
David Payne
David Payne
