Question about Malber WD1000 Front Load Washer/Dryer
Dryer doesn't start
I pushed in cold water and half load, turned the dial to the right temperature, pressed start but nothing is happening.  I read somewhere the safety thermal switch might be turned off, and so I might need to reset it.  The source says: located under the top of the machine.... hmmm... what does it mean? Does anybody know where this switch is? or what else could be the problem? The washer works perfectly well.  Thank you!
  • isadeco Jun 14, 2009
    Thanks Rylee. Just reading your answer now as I had to go away for a few days. Plugging the machine off doesn't work, so I will get the part and try to change the safety thermal switch. However, when you write "The heating element is only about 5% likely." -- do you mean there is only 5% chance this is the problem? What else could it be? This is a machine which is only a year old and was used very little. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Try turning off your machine and unplug it from the wall socket for 10-15min.s. After this is done check if it works fine. If it doesn't work then check for the hi-temp thermostat(Safety thermal switch). They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord).
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
When I turn the dial on my dryer to preset drying time and pushed the button the dryer started and ran but after a half hour it was still at the same location as I had put it and the clothes were stil
Sounds like the dryer fuse-able link has opened. If this happens the timer will not advance and the heater will not go on. Check the schematic of the dryer to see where it is located. When located check the continuity, if open, that is your problem. They are located in places that are not easily accessible (usually).
Sep 21, 2014 | Dryers
It's a gas dryer, just dried a load fine put in the next set the heat dial shut door and pushed the start button, nothing happened.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Kenmore Dryers
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Waher fills and then quits, won't start the wash cycle
LAT7300AAW that is your model number AZ103872 FD that is your serial number
Jan 02, 2009 | Washing Machines
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Neff 5644 - how does it work!??
"e" is economy - ignore this there is a selection of spin speed - most people use the fastest half load is what it says - most people wash a full load so ignore the temp dial just selects wash temp. for normal washes set to 40deg can't remember the symbols on program dial but think they are fairly self-explanatory this machine is just a washer remember to check the filter regularly
Jun 14, 2007 | Neff W5340X0 Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
