Let our Experts solve your ''Intel R Pentium R 4 CPU 2 80GHz update drivers have with upgade 500 to 1 g memory'' Problem
I have a Pentium 4, 3.00Ghz 3.01 Ghz desktop and wish to upgade its am memo fom 500 mb to 4 gb or even 8gb. Is this possible? and what memo should I look for on ebay ?
You need to find the motherboard manual with all the specifications in
to find out what type to use.
Also note: There's no point putting more than 4 gig in if you only have Windows 32 bit.
Jan 25, 2012 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I HV A INTEL CPU 945D WHICH HAS A PROBLEM OF SOUND DRIVERS
You can go here to download drive and have the site check for updates fr all the drivers http://downloadcenter.intel.com/Default.aspx
Mar 23, 2011 | ASUS Pentium 4 , Pentium 4, Pentium D,...
Intel r pentium r 4 cpu 3.00ghz drivers
sir i have not sound driver. my computer is intel(r) pentium(r) 4 cpu 3.00ghz. windows= microsoft windows xp professional version 2002 sp 2 v.2096.which sound driver install in my computer? sir pls tell me somthing.
Oct 30, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have Intel(R) Pentium(R) 4 CPU 2.40 GHz I don't know which drivers to install Video Controller driver and from where ?
if you can get online, Go to
http://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr
And on that page there is a link that says Run Intel Driver Update Utility that should run and find all the intel drivers you need, Usually on a Intel board it's usually Intel graphics or Nvidia either site will have a similar download to auto detect what you need.
Sep 10, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
X86 Family 15 Model 4 Stepping 9
There are at least four processors which are described as Family 15 Model 4 Stepping 9 f=2.66GHz
These are described at http://www.cpu-world.com/cgi-bin/ajax/parts.fcgi?PART2=Intel+Pentium+4+CPU+2.66GHz&CGI=OUTPUT%3DW%26PART%3DPART2%26ACTION%3DMATCHFP%26WANT%3DURL%26FIELD%3DPART2
Drivers are OS dependent. Depending on your OS try the Intel driver update utility http://www.intel.com/p/en_US/support/detect/
or go here
but I do not think you will find drivers, because these depend on your motherboard make and model, and your OS, not the CPU
Go to either/and your motherboard manufacturer's website and/or your system (computer) manufacturer's website for drivers.
10.December.2014
Feb 26, 2009 | Intel Pentium 4 550J, 3.4 GHz...
My disk drive was lost
no it's not lost still there
right click my computer then properties
hardware then device manager scroll in there and see if your dive shows there then let me know
Dec 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Motherboard driver
i lose my Merury Mainboard Cd i nead the Drivers for PI945GCM Can any one help
Oct 21, 2008 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
