Question about Dishwashers
Washer was purchased in 04 and was extremely quite until a few weeks ago. now there is a loud whine when washing, not when pumping the water out.
  • 1 more comment
  • mail219 Jun 03, 2009
    would think the whine would happen when water is pumping out if bearing is bad. no noise when pumping out
    any other thoughts
    problem is loud whine when washing. doesn't happen when pumping water out. whirlpool dishwasher purchased in o4 and verry quite until a few weeks ago.
    Sergeant:
  • 273 Answers
You may have something stuck in 1 of the rotors you should be able to remove them if you can give both the rotors and housing a good clean i had a similar problem and found a few salt crystals stuck between housing and rotor if you can't remove them try an intensive wash cycle with the dishwasher empty
Posted on Jun 03, 2009
  • 479 Answers
might be the motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. The motor has screws that holds it together, please took them out and took the motor apart.
please make old beaing off the shaft and put a new one by checking the specification of the bearing and normally it is 22mm x 8mm x 7mm bearing.
Good luck
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
Water refills when not on
We came home to a flooded basement because it appears the washer filled on its own when we were gone for several days and are in the middle of an investigation about why/how this happened. If anyone has any information on similar malfunctions please let me know. We purchased our machine on 1/22/05.
Sounds like there may be a mechanical problem and Maytag has some explaining to do...
Nov 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Leaks water and is abnormally loud during spin cycle
Sounds like the bearings are broken. This is a serious issue and may be quite expensive. If your appliance still under warranty, contact the manufacturer for assistance. If not, don't be afraid to ask the customer service if they can provide some assistance to replace your washer (as the repair will be quite expensive), perhaps the manufacturer may be able to provide a rebate or something like that if they appreciate you as customer.
Good luck.
Aug 31, 2009 | Amana Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
I just bought a Frigidaire Affinity washer model #LTF6700fs about a week ago. Starting yesterday the washer stopped draining. We can hear the motor working to pump it but no water is draining. My...
perhaps not in that hose but in the pump housing just below it, quite possible that someting is jamming the imopellar preventing proper draining of water
Mar 18, 2009 | Frigidaire Washing Machines
Kenmore Washer
if whines when filling not pump but fill valve try adj faucet toward off slowly this may reduce noise also be sure all screens are clear ..replacement not necessary if you don't mind noise ..now if noise in pump out remove hoses to pump on bottom remove 2 clips holding pump on remove pump and clean
Jul 31, 2008 | Washing Machines
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
