Question about Water Heaters
What causes Water to leak at top of Rheem 21V40S-2 hot water heater? I shut incoming cold water off and dried up the water on top so I could see where water is coming from. I dried it up and turned water back on and all three cavities on top seem to fill up at same time. ?????
  • 332 Answers
The tank is broke and the water is under pressure , the insulation around it is forcing the water to come out of the nearest opening,, need to replace the water heater asap,,, it could blow at any time then you will have a flood
Posted on Jun 04, 2009
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
My Rheem electric hot water heater occasionally leaks water then stops completely. This has done this three times now over the pact couple years.
It sounds like TP valve is releasing water, but you don't describe where water is located.
Run through process-of-elimination check list on following link:
http://waterheatertimer.org/Leaking-water-heater.html
1) If problem is TP valve, event could be caused by 'stacking'
Stacking is where you draw amounts of hot water many times in succession.
Top part of heater is plenty hot because water heater is keeping up with hot water draw.
Incoming cold water enters bottom of tank through dip tube causing thermostat to read cool temperature and activate burner or element. This causes higher than ordinary temperatures at upper part of tank and TP valve reacts by releasing water.
2) TP valve could be going bad.
http://waterheatertimer.org/How-to-replace-TP-valve.html
3) Improper venting can cause gas water heater to have water on top of tank or dripping down inside tank where it shows on floor after rusting out combustion chamber.
4) Thermostats are old or not reading correct temperature.
Turn down thermostats:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Replace gas valve on gas water heater, and flush tank.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Replace electric water heater thermostats
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem Water Heaters
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water is putting the burner out
if you check the bottom of the tank or there is water on the floor constantly..check the top of the tank most of the time the shut off valve is leaking or the hot cold connection on the top is leaking..if both these are dry then there could a crack in the tank
Jul 05, 2010 | Rheem Water Heaters
Water leaking from the bottom of the big PVC pipe parallel to the water heater
What is the leaking pvc pipe connected to? The T & P valve on the side (or top) of the tank? Or is it an incoming cold or outgoing hot water line? If you have just lit the water heater, the T & P valve may drip, but only for a little while and it will stop. The T & P (temperature and pressure relief) valve may be bad and need replaced. Turn off the incoming cold water valve and turn the gas valve to off position. Then drain the water heater using the T & P valve, it will stop draining when the water level is just below it. Remove the T&P valve and replace with new one. Use thread sealing tape on threads. Or call a plumber if not sure.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
It's leaking slowly from the top It's a Rheem 82v52-2 water heater and we came home and there was a puddle of water in the floor. It's a slow and steady leak. It starts at the top on the right side. I...
if the line feels cold its the fill line if warm its the hot line either line try to tighten the connection if no good or leak is from solder or connection if u have valves to and out shut them off or turn off main open a faucet relieve pressure at heater either solder the line to repair or if connection Teflon tape joint and retighten connection good luck and thanks for using fixya
Oct 10, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 21V40S-2 does not heat water
all brands and models have a flow switch which protects the heat exchanger from overheating, a very common problem is calcium build up in the heat exchanger which reduces flow and causes the flow switch to shut off the burner. Can be fixed by descaling the heat exchanger. We have a kit available at heaterup.com its safe and easy to use.
Jul 03, 2009 | Bosch & Tankless LP Hot Water Heater
Water leak at top rheem 21v40s-2
you need to replace the water heater, the tank is cracked and under pressure so it is forcing the water to the nearest opening
Jun 03, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
177 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
