I'm using a Brother MFC-5440CN printer-Scanner-Fax. Whenever I clean my registry using various cleaning tools (JV16, Advanced System Care 3, etc.)' the cleaning application deletes one of my printer's registry keys. As a result, after reboot, I get the following error message: Failed to start ControlCenter 2.0. The required registry information in missing''. Can you suggest a way to identify this missing registry key? Holding this information may let me both keep my registry clean and avoid recurrent installations of my printer's software.
    Sniper:
  • 86 Answers
What you can do is check the registery before you do the cleaning, and compare with afterwards. The registery keys associated with ControlCenter is found in HKEY_LOCAL_MACHINE\Software\Brother\ControlCenter and in HKEY_CURRENT_USER\Software\Brother\ControlCenter
Try taking a screenshot of the keys extracted, or export them, to easier see what's being removed.
Posted on Jun 03, 2009
Brother MFC 5440CN The black line of the ink is "clogged"
Hello sir; If you use auto feeder and print out with black line then you have go to clean the glass (small portion one ), if you make copy with black line then you have go to clean up print head( if your machine is inkjet) or you have to replace toner cartridge ) if your machine is laser jet).
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
Trouble shooting, unable to clean
hi friend,
Brother MFC-5440CN
http://www.brother-usa.com/MFC/ModelDeta…
user guide,
http://welcome.solutions.brother.com/bsc…
pdf
http://welcome.solutions.brother.com/BSC…
"Unable" to Clean pg 11-4
try starting by unplugging power and usb for 30 ~60 seconds to cancel out possibility of software conflict glitch ,
possibility of fax in progress,
and also try re-seating ink cartridge,
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Brother Office Equipment & Supplies
Unable to clean-need trouble shooting guide
I am having usual problem of unable to clean (Brother MFC-5440CN). I have looked for any strange object but can't find any. Could this be amechanical problem and what is solution?
May 27, 2009 | Brother MFC-5440CN All-In-One InkJet...
My printer not working
it sounds like a manufactuer defect
May 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
No USB Port on printer
It is inside the printer, near the ink cartridges.
Apr 19, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Oct 24, 2006 | Brother MFC-5440CN All-In-One InkJet...
109 people viewed this question
jasbo
jasbo
