Question about Brother BRTPT65 PT-65 Label Maker Printer
CHANGE FONT Can you tell me how to change my font on a Brother P-touch? I have tried CODE and SIZE SET and SIZE and it just displays error every time. Thank you.
The printer can be stuck in double line mode, although it indicates that it is single line mode. Switch between the two modes, pressing " enter" and " clear ", until you are in single line mode again. Now you can change text size again.
Posted on Dec 09, 2010
    Sniper:
  • 86 Answers
If it displays error, it seems that the tape you have inserted in the machine does not fit the size settings that you've set. Try using a wider tape, or only change the size setting one step, to see if there's any difference at all or if you receive error on all changes.
Posted on Jun 03, 2009
How do I increase font size on my Hudl?
Device > Display -
Touch this option to change the display settings. On this screen you can set the brightness, change the background wallpaper, set the auto-sleep time or change the default font size. You can also enable connectivity for a wireless display
Dec 20, 2017 | Computers & Internet
How do I change font size on p-touch 1880? I don't understand the manual.
To change the Font Size follow as below.
Press the 'Fn' Button
Then using the '' Buttons move to SIZE and press the 'OK' Button
Then again using the '' Buttons select which Font Size you require (Large, Medium, Small or Max) and press the 'OK' Button.
Jul 30, 2011 | Brother P-Touch PT-1880 Printer
Brother p-touch model 1880 label maker- how do you change the font size
To change the font size, do the following:
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
* SIZE1 equals Standard Size.
* SIZE2 equals Double Width.
* SIZE3 equals Double Height.
* SIZE4 equals Double Width & Double Height.
* SIZE5 equals 4 x Width & Double Height.
* AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
How do I change the font size on my lavel maker
If you go into the menu, and you go down to font, hit enter. It should bring up size, style etc. If not, please tell me.
May 11, 2010 | Brother P-Touch 1180 Label Printer
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
Font size
You will find the instructions manual at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_1180_EN_132.PDF
There is a section that deals with font size:
1. Press Function
2. Press the left or right arrow button until SIZE is displayed
3. Press Function again (or the return button)
4. Press left or right arrow button until you see the size desired
5. Press Function or return button to apply changes.
It is graphically explained in the pdf at the link attached.
If I have helped you, please remember to rate me as such. This way I can continue to help others. Thank You.
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
ERROR appears and won't print
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Changing font size
Try changing the font size in Notepad/Wordpad/Microsoft Word. If that fails, then go to the settings on your printer, and it should have a default size on their that you can change. Change it to 0 and it will go to all sizes allowed.
Hope this helped -CA
Nov 08, 2008 | Brother Multi-Function Center MFC-240C...
Brother BRTPT65 PT-65 Label Maker Printer Logo
714 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
