Question about Philips GoGear SA178 MP3 Player
My Phillips MP3 scren is broken and i cannot see the display. Is there anyway i can reset the player so i can at least use it. I also think one of the settings is stuck on repaat one
My Phillips MP3 scren is broken and i cannot see the display. Is there anyway i can reset the player so i can at least use it. I also think one of the settings is stuck on repeat one track. Is it possible to operate it from my computer
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
Posted on May 30, 2008
  • 7 Answers
SOURCE: Delete songs from MP3
Try when plugging it in go to the start button.
Click 'Computer' and there should be an icon saying 'Phillips'.
Click and go into the songs and right click to delete.
Not sure if this'll help you out.
-AJ
Posted on Nov 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips 30gb will connect to computer but wont sync anything
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: My 2gb phillips mp3 player will only show the
Reset the player
If that fails:
If still nothing:
-Tha Mp3 Doctor
Ballinville
  • 5 Answers
SOURCE: GoGear SA5285/37 Digital Media Player Phillips go gear 8gb
no work is dead only the baterry in the screen appear
Posted on Dec 03, 2009
Need to reset phillips gogear 2GB SA2627/37 as it displays PHILLIPS on start up & shuts down. On connecting to PC, it displays OK TO DISCONNECT and doesnt even recognized by PC as USB device.
Your player might hang up. Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software and repair device with it.
Contents will be removed by using the repair function.
How to do it is described on the manufacturer's web site here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&mid=Link_FAQs&view=aa12_view_partial.html&session=20110504030502_93.189.114.198&list=aa12_list_partial.html&slg=AEN&ctn=SA2627/37&dct=FAQ&refnr=0073454&faqview=1
Thanks.
gylacz
May 04, 2011 | Philips GOGEAR SA6045 MP3 Player
Can' t scren
Please repost your question. What do you mean "Can't scren?"
If you can repost your question including the model again and include your issue so that we can help you solve your problem.
Good luck!!
EJ
Dec 26, 2010 | SanDisk Sansa e250 MP3 Player
I have a Phillips GoGear Mix 4GB frozen.........
I had a frozen screen too just five minutes ago. I thought it was completely broken until I realised there was a reset button on the side of the mp3 ^^ Hope this helps
Apr 10, 2010 | Philips Audio Players & Recorders
Mp3 player not starting up
Try the firmware upgrade to see if it will relaod the ysstem files. Also, try the Sansa Recovery Too lfrom the sandisk website as a backup. Some players allow you to reload the firmware once a system file has been deleted, but others do not allow it.
-Tha Mp3 Doctor
Oct 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Replace the display screen
Hello acid_hussain,
Sorry to hear about your MP3 player. Unfortantely, physical damage such as a cracked screen isn't covered by most manufacturer's warranties. The unit is likely repairable but you will probably have to pay for those repairs.
To get service you should contact Phillips through their website or take the player to a local consumer electronics store that offers repair servies, such as Best Buy™.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Philips PMC7230 Digital Media Player
Phillips go gear stuck on Repaired all contents cleared!!!
i held the volume+ button in while i plugged the usb cable. the computer recognized new hardware was found. i opened the phillips device manager and hit the repair tab. it automatically ran a repair through the mp3. then i installed new firmware through the phillips device manager. i lost all my contents but windows media 11 sync all my music back. THANKS ANYWAY!!!!
Jun 27, 2008 | Philips GoGear SA178 MP3 Player
How to erase music off phillips sa3104 mp3 player
Open windows media player, pick music, pick phillips go gear, displays music, click on music, choose delete
Jan 03, 2008 | Philips GoGear HDD075/17 MP3 Player
Phillips SA31XX mp3 player
Check page 26 of the user manual: http://www.richersounds.ie/images/product_1949.pdf
Aug 26, 2007 | Archos 504 500870 Digital Media Player
Phillips HDD1630 6GB mp3 player
It sounds like your hard drive is broken
Jan 10, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA178 MP3 Player Logo
49 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
