Question about Lowrance LCX-25c GPS Receiver
My unit just flashes on the last position that was stored and wa
My unit just flashes on the last position that was stored and want pick up a satellite. It worked fine the last time. And it doesn’t make that sound when you open the card drawer.
I checked all the fuses and connections and cant seem to find a problem.
  • 39 Answers
It may simply be trying to load the almanac and ephemeris from the satellites. This can take up to 1/2 hour with a strong GPS signal outdoors.
Posted on Jun 04, 2009
Why does the klik2 unit stop working when mounted to wa ll?
It should work in any position. Is there metal in the wall that could shield the remote from the receiver? Try the remote in different positions to see if you have a dead spot due to shielding.
Jun 15, 2014 | Chamberlain Clicker Universal Garage Door...
Wa 1070t willnot transmit signal from the outside sensors to the display
I have a WA-1070T with same problem
brand new would not communicate
look very carefully at the positive end of the battery connections in the outdoor transmitter
One of the two batteries were not making a connection
I had to cut out a small piece of plastic that interfered with battery alignment
As soon as batteries are installed in remote transmitter you will see a red LED flash a few times
After I made this correction everything worked
May 26, 2014 | dr. Tech Solar Transmitter Wireless...
Wa-1070t will not transmit signal
May 19, 2014 | dr. Tech Measuring Tools & Sensors
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
I just purchased a Rebel T2i and a 580EX II Speedlight. After approximately 50 flash photos, the speedlight shifts slightly to the rear and it appears the contact between the speedlight and camera...
It would appear to me that the flash was not locked in position and has move back on its mount which would cause the flash to go into complete manual mode or loose complete communications between camera and flash.
I would suggest shutting the camera and flash off remove the flash first unlock the little locking leaver on the bottom. The 580EX and the 580EX II differ in that the 580EX II has a leaver rather then the huge locking screw. Once apart reinsert the flash unit back into the camera hot shoe making sure that the forward edge of the flash mount is seated as deep into the Hot Shoe as possible and lock it into position. It should click into lock position. Biggest thing I have with my "crew" is when there is a flash installed on the camera they pick the camera/flash unit up by the flash that's a real bad thing cause the flash mount is light plastic and it'll ether break, twist or even unlock the flash enough that the camera falls off of the flash. Pick the assembly up with both hands lens and body. I'm not saying you are doing this but when my crew/working associate's do this I'm not happy.
Although that new switch idea is great it also can be unlocked without noticing.
Diagram
Jan 06, 2011 | Canon Speedlite 580EX II TTL Flash
It was working good last year, but this year we have to drain the water every 4 or 6 hours beacause the unit stop workin because all the water.
Normal Operation. Part of the unit's job is to dehumidify. If it is more humid this year than last, it will fill up quicker. One of the pains of a portable A/C unit.
Jul 18, 2010 | Sunpentown 12,000 BTU Portable Air...
What store carrys motherboards? I need a ASUS P5P43td. I live in Bellingham, Wa. Thank you
Hi there please click the link below & order your Asus motherboard.
1. LINK
2. 2011 Young Street, Bellingham, WA, United States‎ - (360) 647-1881
Call them. Thanks & waiting for your feedback.
Feb 18, 2010 | Office Equipment & Supplies
Sunpentown WA-1210E
The unit is probably undersized for the space. Rule of thumb is 12000 btu per 500 sq ft. Take a thermometer and measure the entering air to the unit and then hold it in the outlet air stream you should see a temp. difference of about 10 to 15 degrees if it functioning properly. Hope this helps 2rns4u <*{{{>(
Jul 22, 2009 | Sunpentown WA-1210E Air Conditioner
94 Plymouth Sundance.. engine light and sluggish from dead stop! Help
What you do is turn the ignition to the "on" position and back to the "off" position 3 times. On the last "on/off" cycle, leave the key in "on". The check engine light will start flashing. The first group of flashes is the 1st number of the code. There will be a pause and then a 2nd set of flashes will be the 2nd number of the code. If there's more than one code, there will be a pause and then there will be another set of flashes for the next code and so on. A Haynes or Chilton's repair manual, available at any parts store, will tell you what the codes mean.
Jul 09, 2008 | 1994 Plymouth Sundance
I have a WA-1230E and it was working fine yesterday. When I returned to the room, it was off and only the "comp" light was flashing. No button would have any effect and only unplugging the...
The flashing light indicates the water tank is full. Unscrew the cap at the back of the unit then pull the plug to drain it into a pan. Replace the plug and cap. The unit should work as normal.
Jul 06, 2008 | Sunpentown Heating & Cooling
Lowrance LCX-25c GPS Receiver Logo
230 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
