Question about Philips Magnavox 51MP392H Rear Projection Television
I have a philps 60PP9202-17F when i adjust the color and get it about right on it shuts off. Help
  • Philips Master
  • 3,459 Answers
Do not mess with the knobs in the back of the TV set unless you know what you are doing. 99% of the time they are not the cause of your problems.
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
65af323.jpgI have a philps 60PP9202-17F when i adjust the - 2c07611.pngmi
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photosI have a philps 60PP9202-17F when i adjust the - 645fba6.jpgence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the bI have a philps 60PP9202-17F when i adjust the - 0667c5f.pngence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 21, 2009
I have a 9P5511c101 philps PTV836 in our shop. How do I adjust the vertical.
That model has no adjustment for vertical unless you are speaking of convergence?
Mar 30, 2012 | Philips Magnavox 9P6034C 60" Rear...
On the printer window, it says: Color Regist Error
Hi there
I beleave it is to perform the manual color registration adjustment.
Press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust.
But you may have to do this manully adjust all till get right,
Sorry cant help you any more than this.
All the best Pineworks
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
I have a philps universal sru 3003 and i need the
1st, grab the remote control with your right hand, then stab it into your right eye socket as hard as you can. If you are not bleeding, repeat this step until you are unconcious and unable to think about how frustrated you are at not being able to find the answers you desperately need online.
Jan 21, 2010 | Philips Televison & Video
LC 4431 SHUTDOWN
could be getting too hot (fan malfunction or dirty), lamp (also hot from dust), or a power problem. so, clean it out and listen for odd noises. if it still does that, you might need to replace the lamp ballast.
Sep 02, 2009 | InFocus LP70+ Multimedia Projector
03 philps 52' rear projection red and green lines laping?
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Trouble with philps tv
First check to see if all cables and settings are correct according to the manual, if not it could be a bad board inside the set that costs $180.00 to replacce
May 18, 2008 | Philips 27PT6441 27" TV
A message in the monitor saing waiting for automatic adjustment
you can try to solve this problem eith you're graphic driver program like nvidia control panel. i resolve this messing with "adjust desktop size and position". i hope this help!
Mar 25, 2008 | HP Compaq FP5315 15" LCD Monitor
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Color printing
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Philips Magnavox 51MP392H Rear Projection Television Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
