Question about Uniden Cordless Phone
Got new cell that I want to pair via bluetooth to my cell fusion cordless DECT 6.0 phone. It asks for a passcode, is this a number I make up for both the cell and landline? My old cell connected but I don't recall the passcode I used for it. Thanks for help.
I was able to find the manual online and follow the instructions which worked perfectly. Thanks.
Posted on Jun 04, 2009
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
Jul 10, 2010 | LG GW300 Cell Phone
I can't connect my Samsung Jet with my PC via Bluetooth. What am I doing wrong?
to connect your samsung phone to a pc via bluetooth you need to follow the steps.
1. install your samsung pc suite NPS,
2. open your phone bluetooth.
>> go to menu, select bluetooth, select settings under bluetooth, make your phone bluetooth's visible,
3. go to your computer, open your bluetooth, right click the bluetooth icon on the system tray, they are grouped and can be located near the clock.
4. select settings for your computer's bluetooth, make it discoverable, check the discover services.
5. under the computer's bluetooth panel, you can see there add device, click add device.
6. once the computer search for your phone, pair them with passcode like 1234, or 0-9 digits, it's up to you to assign the passcode but make sure they will be having the same passcode. ( both computer and phone).
once paired you can see them there in your phone's bluetooth panel, your computer and your phone together.
>>to check if successful connection was achieved, select a file from your computer, right click and send to your phone.
>>do the same thing for your computer, select a file from the phone and send it to your computer, but you need to confirm that your computer will be receiving a file from a paired bluetooth, by clicking the balloon
message at downright corner of your computer where your bluetooth is located.
regards...
Mar 02, 2010 | Samsung Jet S8000 Cell Phone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
I can't receive any mp3 songs and pictures via bluetooth
when it ask passcode, its an security protection, u'll just have to input any number, and same as to the other phone. like 1234 and you'll input the 1234 passcode on which phone you are pairing with, try changing you setting in your message setting cause, mostly when via blue tooth it stores on your inbox.
Jan 04, 2009 | Nokia N72 Cellular Phone
Bluetooth passcode
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
As for pairing your headset, try this link:
http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
Jun 11, 2008 | LG VX9400 Cellular Phone
Forgotten bluetooth passcode
CupidsEnemy - passcode 0000 try that...it will work
Guest - just connect and when ask for passcode type 0000
Dec 06, 2007 | LG KG800 Cellular Phone
Uniden Cordless Phone Logo
162 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
