Question about LG WFT1071TP Top Load Washer
PROGRAM LOCK I have someone who is doiing my washing. I need to know if a person can lock or program the machine so that she will only be able to use certain cycles. Please help, she is only using the quick wash cycle and my clothes is never clean or still smell.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Not familiar with your model...not normally thou in your manual it should be under 'programing your options'
Posted on Jan 03, 2008
0 characters
3 Points
How to fix door on Samsung Washer model wf210anw. It makes 3 very hard clicks prior to starting.
Has the sound changed? The door lock assemble can be loud and sound like its faulty. If the washer completes cycles, then door lock is working correctly. One thing to check is the strike on the door. Look for anything that is odd or doesn't look right. A damaged strike can create extra noise. Good luck!
Jan 29, 2016 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Key Lock on the Display
you must do this with ever program until the lock is off
you know the last program you used
switch on
hold the clock button for 5 seconds
did it unlock if not switch try next program
Jan 06, 2014 | Bosch Washing Machines
Deactivate child lock on simmens washing machine
On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds.
Nov 20, 2012 | Siemens Washing Machines
My indesit washer wia111 starts to wash but once it has done the main wash and goes to rinse the machine stops working and the red door lock indicator goes off
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into and run the program to finally drain shut off and open lock. . If this does not happen then the voltage at the valves,motor and pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Please check the link below:
Jul 26, 2011 | Washing Machines
My front loader hydrax model washing machine cannot open its door even after the washing cycle has completed I have tried to contact the local dealer and is taking a very long time to come inspect and my...
If the drain pump/alve has worked and the water has drained off the machine then you can reset the door switch by pushing the safety lever down to release the lock on the door .
Now this can be done only if you can observe very carefully using a good position and light to locate the door lock and release lock lever from the program controller.
Once this is done , check the program without clothes on a low wash and see if the door jams or if this is a fault on the program controller unit.
May 19, 2011 | Thomson Washing Machines
I have tried everything, but my front loader (Samsung J845) door won't open. I can't get a repair person until Monday and the clothes trapped in there are rotting. Have only had machine for two years and...
Remove the plug and see if the program can be activated. If not try to reset the program, if there is a failure to shut off the door lock it is possible that the program controller has failed.
If so you will need to first of all drain off the water in the tub by removing the drain hose. Please make sure that the washer is kept out to drain or there could be flooding inyour room. Once the water has drained use a long head screw driver to manually release the lock of the door.
You might have to use agood light to see the latch to release the lock.
Nov 03, 2010 | Samsung WF206ANS Front Load Washer
End light flashes four times/sound signals too, after selecting any program, machine will not start...any ideas?
This is most often a problem with the door lock. However, can you provide the exact make and model of the machine and let me know if the door is locked when it refuses to activate the program.
Also try disconnecting or tripping the power to the machine for 30 minutes - reconnect and see if it starts the wash.
Feb 13, 2010 | Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
LG WFT1071TP Top Load Washer Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
