Question about Zanussi Washing Machines
I have a Zanussi Jetsystem+ 1400 washing machine. I can turn my machine on but it will not fill with water; this is the same for each programme I have tried. I have checked the hoses and the filter
Hello. I have a Zanussi Jetsystem+ 1400 washing machine. I can turn my machine on but it will not fill with water; this is the same for each programme I have tried. I have checked the hoses and the filter - they are fine - and I have checked that the door is properly closed. It worked fine last night but not today.
  • 1294 Answers
SOURCE: Zanussi Washing machine
Try some WD40 on the door switch.
Posted on Jan 25, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Posted on Oct 09, 2008
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
Posted on May 19, 2009
caroldon
  • 17130 Answers
SOURCE: Hello I got zanussi jetsystem 1200. The washing
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 07, 2012
What does fault code e30 on a zanussi jetsystem 1400
Activated anti-flooding device. Try to find leaks in the bottom of washing machine.
Dado
Aug 08, 2014 | Zanussi Washing Machines
May 19, 2009 | Zanussi Washing Machines
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem 1200 wahser dryer problem
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Oct 07, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
