Question about Kenmore 75962 Gas Dryer
I have a kenmore gas dryer 110.74832400 doesnt heat
I have checked all lint problems, the wires going to cord. The dryer does tumble. The light is on but the gas may or may not come on, and if it does it only comes on when started from the start position. I know if it does come on, it will eventually shut off because my clothes get a little warm but not dry.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
You stated you checked all lints roblems. Just to make sure. Did you remove the lint catcher completely on the inside? If not take that off and clead the lint out of the inside of the duct. Also lint can build up inside the lint duct on the rear of the drier and in the duct going outside of your home.
Posted on Jun 03, 2009
3 Suggested Answers
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 2694 Answers
SOURCE: Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Posted on Jan 25, 2010
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
Dryer tumbles but no heat cleaned out all lint still not workin
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 29, 2011 | Kenmore 98702 Stacked Washer/Dryer
My dryer tumbles but does not heat. I've cleaned the lint vents still no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Tumbles but dont dry
74632 is not a model number. But what you have stated the dryer probably has a bad thermal switch. Cost around $6-8. Unplug dryer, remove back, with a tester test everything that has wires hooked to it. Test from one side to the other to see if power goes through, if not replace that part. They are small round or small rectangle with two wires connected to them. Check the one one the duct first, this one usually goes bad. Vacuum out all lint out of dryer and hose to exterior, excess lint will cause dryer to heat up and blow this part.
May 08, 2010 | Kenmore 74632 Gas Dryer
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryer won't heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Kenmore HD gas dryer won't heat up
Heating element
Thermal fuse
Wiring
Jul 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 75962 Gas Dryer Logo
179 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
