Question about LG Washing Machines
Tromm LG Washer Model WM0532HW light comes on LE and the washer fills with water sounds like a jet, light LE comes on and washer won't run
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
rickzilla
  • 706 Answers
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
  • 8 Answers
SOURCE: LG TROMM CLOTHES WASHER - "LE" ERROR CODE
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
Posted on Feb 28, 2009
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Posted on May 16, 2009
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
Washer is filled with water after running it completely damaged my blanket because it got soked in water!!!
your pump motor is out, whats your model number and serial number, i could probably source the pump motor part number for you......if your washer is filled with water, and not draining, your motor is out........these LG motors go out fast....
Feb 09, 2010 | LG WM2688HWM TROMM SteamWasher
LE light came on and washer stopped. Tried another load, washer filled but does not run
The LE code means a motor error. Lock error, you may have to try replacing the Hall Sensor and if this doesn't fix the problem then you need to replace the Stator as there may be aproblem between the Stator Assembly and the main PWB Assembly.
Nov 08, 2009 | LG WM2688HWM TROMM SteamWasher
Trying to wash but le comes on the screen
le code is pretaining to tne motor, overloaded ,too much soap, or bad motor .disconnect power for a minute and try agian if proble presist you'll have to have motor repaired
Dec 20, 2008 | LG WM2688HWM TROMM SteamWasher
Washer stops with 'LE'
Most likely lack of flow in drain water. Pump inlet could be restricted. I'm guessing it must be sudding up in the rinse cycle and shuts down when it spins up... This is from all the water in the tub.
1. pull the access door on the lower left. You will need a blade (flat) head screw driver for this.
2. You should see a hose. and a knob. Get a small bucket, or 1L soda bottle. Pinch the hose, pull the cap and let the hose drain the water. You might have to pinch the hose and cap it if your bucket gets too full so you can empty it. If you skip this and just open the pump trap, be ready for water to come out, unless it is the inlet port of the pump housing that is blocked
3. After the water is out, you can open the knob for the trap to the pump housing.
4. Make sure the trap is clean. If it isn't, then this is most likely your problem. If it's clean then you want to look into the pump housing before putting the trap back in. Use a flash light. I found a bottle cap ontime holding back the water, when i pushed it water came gushing out.
5. If you can't see a block from this method, either of the follow could be the problem.
A. Pump motor not working or power not starting the pump motor.
B. inlet or outlet hose have a major restriction or blocked.
In this case it will come down to fixing it yourself or calling someone.
Dec 29, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
437 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
