Question about Mitsubishi WS-65511 65" Rear Projection Television
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Has a 2blink sequence for 5 times
Posted on Jun 17, 2009
  • 126 Answers
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Posted on Jun 03, 2009
SOURCE:
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
LG PLASMA 42 INCH WONT TURN ON!
Sure, you will need to replace the power supply circuit board asap. this will fix your issue.
Jun 03, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green indicator light flicks about 3-5 times
The power supply has likely detected a short circuit. Hold the front panel INPUT and MENU buttons down for 5 seconds then read the code from the green light. If the light flashes a 2-2 code (2 flashes, followed by a 1/2 second pause, followed by 2 flashes) then pico fuses are blown. A 1-2 code indicates that nothing is wrong. The likely cause for blown pico fuses (FA904 & FA905) is a bad convergence driver IC. The PC board must be resoldered to replace the ICs and fuses.
Aug 09, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi 65
My TV did the same thing for a couple of years. It is the precursor to the capasitor going out on the DM board. The good thing is that the capacitors only cost around 4 dollars if you can soldier them yourself.
Apr 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
621 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
