Question about Dell 3300MP Multimedia Projector
Dell 3300MP searching for signal
When i connect the projector to the laptop (after turning the projector on first), it just shows searching for signal.
I have checked on my laptop the presentation mode is on. (enable it using Fn+F8 keys).
Also there is no problem with the lamp i guess because the projector turns on and off properly.
It used to work properly earlier.
it just doesnt recognise the signal when connected to laptop, just displays the blue screen giving the message searching for signal.
Please help.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: my acer lap top will not recanize the projector when i press the fn plus thef8 keys
Hi, Try lowering your laptop's resolution (Display Properties) to 1024x768 (or even lower like 800x600), before fn + F8. You can also try lowering the Monitor's screen refresh rate (60Hx). Another setting you can check is Advanced Settings tab or button and check settings for projector (instead of TV). If it works in the lower settings, you can try moving the settings higher until it quits again. If the above does not fix your problem, you may need to re-install your graphics/video driver. Hope this gives you an idea. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 24, 2007
SOURCE: Searching for signal
There is an "Auto search for signal" setting on the projector settings menu. This may be turned off.
Posted on Nov 07, 2007
SOURCE: Hello, My company owns a 3300mp projector, we
I had the same problem exactly. But when I removed the bulb and put it in a working projector it was fine. So now where do I go.
Posted on Mar 11, 2010
SOURCE: Dell Projector 3300MP will not pick up a signal from laptop
anyone got an answer here??? i got same issue
Posted on Nov 26, 2010
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
I have a dell 3300mp projector hooked up to a dvd player and I cannot get any sound. What do I do?
sound form your projector? or from your speakers? set the volume of your projector to maximum. then check your connection cables if good your speakers if working. check all your component have pwoer supply.
Oct 28, 2009 | Dell 3300MP Multimedia Projector
Using a Dell 3300MP Multimedia Projector trying to connect to a mac via usb...says "cannot find signal", nothing happens. What am I doing wrong?
you cannot pass a signal through a usb input. USB inputs on a computer are usually used from firmware upgrades or mouse control depending on projector.
Sep 18, 2009 | Dell 3300MP Multimedia Projector
During Powerpoint presentations, I am unable to play embedded video clips OR straight from a DVD that is minimized on desktop without a lag...on the screen it says 'searching for signal' when I click on...
this is caused by your computer changing resolutions in order to display the video full screen. to decrease this, set your screen size as close as posible to the size of the video
Aug 14, 2009 | Dell 3300MP Multimedia Projector
Dell 3300mp searches for the signal but finds none
you have to turn on the output you want to use in the system perfrences, with the kit plugged in and on.
Jun 05, 2009 | Dell 3300MP Multimedia Projector
Dell 3300mp Projector No Signal found to Digital DVD
Guys, the projector doesn't do HDCP.  HDMI won't work.  You'll need to run over component or VGA.
Jul 09, 2008 | Dell 3300MP Multimedia Projector
Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
Sep 13, 2007 | Dell 3300MP Multimedia Projector
Dell 3300MP Multimedia Projector Logo
184 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
