Question about Troy Bilt 5.5hp Self Propelled Mower
Engine does not idle well. always surging.
Engine starts okay but seems to want to surge up and down with no constant idle.
  • nwpolischuk Jun 04, 2009
    Thanks for the quick response. This unit does not have a plastic carb. It is an alloy. The gas tank is seperate. This unit has a gas bowl with a float and has a primer on it. It seems to run really well if you keep the primer pressed in. dont know why this is so. I have lots of gas flow to carb. there are no external adjustments that could be made to the carb. I dont think there is a screen restricting flow through a nozzle. this is a 6.9 HP Troy built. Any ideas?
    Thanks again for the help.
  • 181 Answers
The nozzle is clogged.if this is a briggs engine it has a plastic carbuator on it.to clean you need to remove the gas tank and carbuator,that the screws out that hold the carb. to gas tank.inside you will find a screen covering the nozzle,carefully using a very small screw driver pop the nozzle from the carbuator.there is an o-ring holding it in.don't lose it.gently blow air both directions through the carb.replace it and start the mower up,surge should be gone now.hope this could help,if not let me know and we can try something else........................
Posted on Jun 03, 2009
  • steve
    steve Jun 06, 2009
    okay,on the side of the carb. there is a screw that looks like an adjuster screw.this is another type of nozzle.carefully remove it.it might be under a plastic cap.once you remove it you need to clean the tiny,and i do mean tiny hole in the end of it.i use a piece of piano wire to reopen thes hole.the wire size i use is 0.010".if you use anything bigger it will get stuck.the nozzle is made of brass.once you get the wire through the hole.run it back and forth so the hole is opened.once you clean this hole,thake an air nozzle and blow through it to get all the dirt and brass chips out of it.reinstall it and starte the motor again.should be no throbe at all.hpe this helped just let me know......
2000 Suzuki Esteem 1.8L.. I went to start my motor & turned it off right before started. I heard some kind of backfire. Then I started it and it's been idling high, the surging. Please help!!
scan it yet, a FULL OBD2 scan? why not?if not.
now is the time...
the 1.8L J18 engine, same as the older Sidekick sports used.
same engine , know it I do.
its the precursor to the J20, (j18 is under-stroked, j20 with many of the same parts. inside)
the back fire means explosion sound to rear end of tail pipe?
yes, that is rich raw fuel in the muffler. plus Air.
if there are exhaust cracks and then engine goes rich this can happen( a double failure)
if how ever BACK means, back to the Air cleaner, then that be different reasons, (timing)
engine now starts.?>
engine runs.? has full power, car drives ok.?
JUST?
SURGE,. you never said.
does engine get hot? 180F or more and holds (y/n)
ever get a full tuneup this decade,
most dont so i tell you, bad spark causes, misfire and raw fuel is wasted to the exhaust and sure can go boom.
surging usually means the ISC can not control idle
so it hunts, (a suzuki software engine on all 90s engines)
PCM errors, inside it. (dangerous too)
a modern car, if idle goes too high the ecu commands the ISC closed
and holds it there solid, (safe way , no hunting allowed now)]
so if this car surges, it's , lean engine.
some think flooding is surging.
and this is usually below 800 rpm,
almost stalls, then corrects, seems like a surge.
next time post rpm range of surge.?????
do not drive a surging engine, do not be like Toyota drivers. (over 800 rpm hot)
surge from 400 -800 rpm is class 1 surge.
surge from 800 to say 2000 RPM is class2, and very dangerous to some folks, (key off, get car fixed, tow it)
The ECU controls idle speeds. (hard coded servo controls)
Mar 18, 2016 | Suzuki Cars & Trucks
When engine warms up it start to surge
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 05, 2012 | 1998 Nissan Frontier
While on vacation, our 2002 six cylinder automatic started acting up. With the gas pedal depressed for normal driving, the car started to "modulate" (the rpms would drop and race back up...
check to make sure airfilter is ok and maf sensor is clean. then check out tps ( throttle position sensor ), here are a few causes of a bad tps sensor--- transmission shift issues, bucking, jerking, idle surging, engine cutoff, hesitation on takeoff, surge while cruising down highway. if light on dash is on get it scanned to find problem code. most auto parts stores will do this for free. auto-zone etc. here are a few symtoms of a bad maf sensor-- surge, slip condition underload. the mass air flow sensor may be degraded or contaminated. stalling, misfiring, poor acceleration. ( a check engine light may not come on ). a lot of times just by cleaning maf sensor cures the problem. GOOD-LUCK!
May 08, 2011 | 2002 Hyundai Santa Fe
John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Apr 06, 2010 | Garden
Engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Oct 11, 2009 | Garden
Continuous cycling electrical system surge
check the alternator out put.it has to be.13.5 to14.5 at idle.your car probably idle rough because you disconnect the battery the computer trying to relean itself. it will effect the idle.
Apr 11, 2009 | 1991 Lincoln Continental
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
Dodge ram 1500 engine rpms surge at freeway speed
those sensors could cause the issue, clean the MAF 1st, also clean the idle system using the following procedure, the IAC can cause cruise surge. I use this to cure these problems all the time.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve (IAC) and throttle valve, they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 13, 2009 | 2001 Dodge Ram 2500 Truck
Troy Bilt 5.5hp Self Propelled Mower Logo
1,605 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
