Question about E-Machines (308714) Motherboard
What and where is the motherboard number on my machine
  • 489 Answers
Is your machine laptop or destop ?
Posted on Jun 03, 2009
Fitting a motherboard to my Samsung WA13V5.There is a terminal under the digital display that does not have a visible matching plug. The motherboard part number is DC92-00278L.
The controller may be applicable to a number of models, depending upon how it is configured. Your washing machine may not use that terminal.
Jun 20, 2016 | Samsung Washing Machines
I want motherboard driver compaq presario v2600
You will first need the exact model number of your laptop.
This can be found on the data plate on the underside of the machine.
Once you have that, your drivers may be found on Compaq's Business Support Page for your machine.
Jan 07, 2011 | Compaq (203966-001) Motherboard
Whats the serial number
If you're looking for the model number for your motherboard, you'll have to open up the computer and look for a string of numbers, usually in a fairly large print, directly on the motherboard itself. Carefully move wires that might be obstructing your view of the entire board, and make sure that anything you might disconnect to get a better view gets firmly reconnected before powering the machine back up.
Nov 24, 2010 | Computers & Internet
TOSHIBA SATELLITE P35. Where is the motherboard part number located?? Thanks, Jim J.
On most laptops (including toshiba laptops), the part number is written beneath the Ram compartment. Open the Memory Compartment, remove the Ram, then you'll see a sticker with barcode and tag like this:
or
In you case, the Part number should be K000018150. This is the part number of your laptop's motherboard.
Not every laptop has visible part number, on some machines, it's not visible unless everything is dismantled and removed from the motherboard.
Here's a link for you (Click here).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 01, 2010 | Computers & Internet
Desperately need specs.& a diagram for hdd led, pwr led, pwr switch. they have been disconnected from the motherboard
What is the part number of your motherboard?
Look on the motherboard for a part number. Usually it is a combination of letters and numbers.
Common motherboards are Gigabyte, MSI, ASUS, Asrock, etc
Type that part number you found on your board into Google. You should be looking for a weblink that points to the manufactures website. eg www.gigabyte.com
If you wish, write down the part number of the board and then go to the manufacturers website eg www.asus.com and then type in your part number.
You will be looking for the motherboard manual once you locate the motherboard on the website. If you do have the manual it is usually shown where the computer case leads go in that manual.
One another note, often with a magnifying glass you can work out what leads go onto what pins on the motherboard pin assembly. for eg the speaker connections are usually marked SPKR (or something similar) and the adjacent pins will be for the RESET, LED, POWER etc etc
Good luck, ask for more help if you need it.
Cheers,
Steve
Apr 13, 2010 | E-Machines (308714) Motherboard
I need to retrieve motherboard information and settings using its serial number
This freeware program should help...it'll give you more information about all the kit in your machine, including the motherboard.  With a bit of luck, you should get the manufacturer and model number too:
http://www.gtopala.com/
Please rate me if you found this helpful.  Thanks.
Mar 08, 2010 | Computers & Internet
I NEED Intel E210882 MOTHERBOARD DISPLAY AND SOUND DRIVERS
The model number you've given us here, is the UL number for Intel, not the actual motherboard model. If you look when the machine boots up, you should see it listed on the POST screen - it'll look like D845PEMY or similar.
Mar 01, 2010 | Intel Motherboard
Hiii sirrr
i personally have not heard of that motherboard type, it would be more helpful if you had a model number. Its an old machine so i would say the best bet is to open the case up and find the model number printed on the board itself. this will help us find the correct drivers and get the machine online
Z33m
Dec 10, 2007 | Computers & Internet
Hiiiiii sir
Hi mate, to find your motherboard model, turn the machine on, as it boots it should show the model no. breifly on the screen. Option to enter bios should be present. If you enter bios the model number should also be shown on screen.
Once you have the model number, u can use google to search for the drivers for that model. download the drivers, then install them on the machine. Reboot and it should work.
another way to find the model number is to look on the motherboard itself, should be on the side or middle.
Once again i hope helps
Dec 10, 2007 | Intel Motherboard
Sound driver problem
The website with all the drivers for your motherboard is here:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=91
Hope that helps - Jon
Dec 08, 2007 | Intel Motherboard
E-Machines (308714) Motherboard Logo
100 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
