Question about Hotpoint BWM12 Front Load Washer
BWM 129 After cycle is finished clothes still soaking wet!!!
After puting my clothes on a full cycle. It seams to finish and they are still soaking wet!!! can any one help!
gittos73
  • 244 Answers
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Posted on Aug 22, 2007
  • 4 Answers
SOURCE: wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Posted on Mar 04, 2009
beltronic205
  • 1474 Answers
SOURCE: i have a hotpoint bwm 129. clothes arnt coming out
is it rinsing okay is it pumping ok if not clean filter located at sump hose
Posted on Sep 30, 2009
  • 353 Answers
SOURCE: my hotpoint wml540 is not finishing cycle,the
check your motor carbons
Posted on Jun 29, 2010
  • 6277 Answers
SOURCE: clothes soaking wet after wash
If you are certain that the spin speed is correct i.e. very fast, I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor not spinning fast enough. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 12, 2011
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
I have run the machine on a daily wash
It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
Nov 20, 2008 | Indesit W 123 Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Not draining after cycle
try checking the filture on the front at the bottom of the machine they some times get full of muck
Jan 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
91 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
