Question about Panasonic DMR-E55 DVD Recorder
Self test problem
Hi please can you help , my DVD recorder keeps going on to 'self test' and will not come off of this at all I have tried to switch it off completely and reset etc can you help ???? thanks kaz
  • cosfi Nov 07, 2007
    I have the same problem just now on aDMR-E55
    is there any hardware reset procedure???
  • 28 Answers
Replacing IC001 STRG6353 maybe the reason on power board.
Be careful when replacing, it is attached to heat sink has five pins, closeby some miniture surface mounted parts.
Posted on Nov 21, 2007
My panasonic dmr ez28 keeps coming up with 'self check did not complete' 1) press OK or 2) Press power to restart. I have tried both but the unit then freezes. Can anyone suggest what next?
The Self Check procedure is like the POST on a computer: upon starting the processor makes a simple test of all the hardware components. If it fails then the defect is very important : a critical part situated on the mainboard has failed and it stops the loading of the firmware . Since all parts are glued then the mainboard will have to be replaced. This will be so expensive that it's going to be cheaper to just buy a new recorder.
Dec 02, 2010 | Panasonic DMR-EZ28K DVD Recorder
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
Self check will not stop
This is very common, please see my earlier posting which will tell you how to repair it, by clicking the link.
DMR E55 Self Checking Repair
Best wishes
Mar 21, 2009 | Panasonic DMR-E55 DVD Recorder
Cannot record onto DVD
we are borrowing the unit and do not have the user manual. we cannot figure out how to record a self made vhs to a dvd. how do we do it? please help, its for a project that is due tomorrow.
Feb 14, 2009 | Toshiba DVR610 DVD Recorder/VCR
Recording problem - DMR-E55
Hi Steve
Please see my earlier answer to this common problem >HERE<
Best wishes..
Sep 20, 2008 | Panasonic DMR-E55 DVD Recorder
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
I have a Panasonic EH100 HDD/DVD recorder. Yesterday I left it on for several hours playing a DVD when I realised I switched it off. Shortly afterwards I turned it on to watch a program and it went into a...
Holding certain buttons down at power up can activate unintended test modes. Wrong sequence can lock up processor! Unplug and let sit for 24 hours to re-set processor. Turn set on as normal. If you can, remove DVD before this procedure to avoid reading at start up
Apr 21, 2008 | Televison & Video
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
