Question about ECHO, Inc. PB-251C Handheld Blower
Can't get my echo to rev up
Echo blower from the local home depot. Ran great for a while but now i give it gas it revs then slowly goes down to hardly any RPMS (still does'nt cut off). Went ahead and bought a second and used the same gas can: not the gas. Fresh plugs filters (oil and air). Starts great jsut does'nt stay on
ideas?
Check your spark arrestor. It's a screen in the muffler. If it gets clogged up, and it will eventually, your engine will start and run, but it will not want to run at higher rpms. You have to remove the muffler, then you just clean the screen. Try that. It's a relative easy fix.
Posted on Mar 06, 2013
  • Kevin Ray
    Kevin Ray Oct 22, 2013
    checking your spark arrestor is completely stupid!
  • Kevin Ray
    don't answer questions if you don't no nothing!
  • 1,040 Answers
Your carburetor needs cleaned, or you need a new carb. kit. If you need tips on how best to do this, let me know.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 08, 2009
    Did this solution solve the problem?
    Jim
  • Kevin Ray
    some people here have no business answering any questions
I have a echo 330 evl it ran good till i left it set 3 years it started easy wont rev got a rebuild kit soaked in carb cleaner all nite blew it out assembled it put gas in started still wont rev
air cleaner is clean? was rebuilt ? good spark plug? is there a air / fuel adjustment screw or a high / low idle screw on the side of carb. that may be out of adjustment? fuel lines are in good shape? (not cracked or broken sucking air in)?
Jan 11, 2016 | Echo Garden
Vintage Echo CS-302. Ran for years with zero problems. Until now. It starts and runs great for about 320 seconds. It will rev to max rpm, then it starts dying. wah, wah, wah,, shuts off. Repeat,same
check for problems in the carby--replace with a kit
check the filter on the end of the line in the tank-- they tend to block up
check for blocked exhaust--- carbined up inside
don't use E fuels as they will not operate on the E mix
Apr 14, 2015 | Echo Garden
Echo pb-251 will not rev up
throtle cable has come off from the carb
Jul 27, 2010 | ECHO, Inc. PB-251C Handheld Blower
Echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Sep 21, 2009 | Echo Garden
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
656 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
