Question about JVC KD-SX780 CD Player
JVC KD-SX780 All of the sudden--just stopped working.. If you touch the "display" button--the display does come on briefly--otherwise nothing.. Any ideas??
There is a grounding tab on the back of the unit just above the antenna connection. This must be solidly connected to a GOOD ground. Found out the hard way myself. Once ground was established, I never had that problem again.
Posted on Jan 12, 2011
Have a code v-pre-v 129 on the display screen
Never heard about this. Send a picture to josetejas@gmail.com
Oct 19, 2013 | JVC KD-SX780 CD Player
I have a problem with my JVC KD-R600. The radio turns on and then it shuts off the display and it won't do anything else. It takes CDs and it would display that is loading but then it will shut off. If I...
Hi have you solved this problem as I am now experiencing the dame problem after I havnt used the unit for some time now and installed into a different car and I am experiencing the same problem as you have mentioned
May 28, 2010 | JVC KD-R600 Car CD/ MP3 Player
My radio will not work
for turn off this radio press power botton for 3 second. if you press only with one touch is for mute. turn on press one secon---turn off press 3 second---1 touch is mute.
Sep 09, 2009 | JVC KD-G140 Car CD Player
My iPOD touch doesn't work with the JVC dvd receiver kd-av7010
Most likely not, because the Ipod needs a USB 2.0 port, the JVC receiver you has most likely has an older USB port version. The cord should not make a difference.
Jun 20, 2009 | JVC KD-AV7010 Car DVD Player
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
Jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Sep 01, 2007 | JVC KD-PDR30 CD Player
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Compatible changer
Vicki As far as I know almost any high end JVC will match a compadable changer from another JVC product I say on MOST they will but to be sure IF I was you I would go into a automotive audio store like ABC warehouse or any good electronics store. NOT the super stores like wally world!! there salesman will be able to tell you if its compadible but your gonna need the model of the changer or borrow your sons car and they will look at it as a matter of fact some stores will even install the dash radio for free if its a simple install after you buy the radio. Hope this helps as I know what its like to get radios and equipment stolen from your car as I used to live in NY and in a period of 5 years I got 4 cars stolen and 12 audio systems stolen.!!!! GOOD LUCK and lets know how this turns out??
Apr 26, 2006 | JVC KD-SX780 CD Player
KD-SX780
Yep May sound silly but do you have a dedicated line for youe B+ going to your amp section or Main B+ Line??? you as well should not I found from expereance use the factory B+ line to run an extras power type radio as its not really built or made for that. also Make sure you double and tripe check the grounds going to the radio as well and do not also use the factory grounds as they should as well be dedicated and that means right from the battery for the grounds.. Now a simple but very good way of getting a dedicated B+ line thats a switched type (only one when the keys on) Is to use a 12 volt 25 to 30 contact rating relay and use the cars original power wire for the 12+ for the relay coil and the ground from the original radio. Now one side of the relay can go directly to the battery and the on side when active can go to the radio.. simple but very efective.
Mar 17, 2006 | JVC KD-SX780 CD Player
JVC KD-SX780 CD Player Logo
181 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
