Question about Attachmate Crosstalk Classic 3.2 Full Version for PC
Need the setup.exe file for attachmate crosstalk software
  • 634 Answers
To setup programs on your computer.
Posted on Jun 04, 2009
Is setup.exe.vbe safe to run?
probably not. .vbe means Visual Basic Encoded script. It seems as though someone tried to camouflage their script with a familiar filename (by prepending setup.exe in front of it. Is this on a CD or a file you received in email or downloaded?
Feb 04, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I cannot install any software. NSIS error!
Hi
1.Go to "Start," click on "Run," type "cmd" in the text box, and then click on "OK."
2.On to the black window that opens up, click and drag the software installation file icon that you wish to install. For example, suppose you want install Google Talk on your computer and the setup file (googletalk-setup.exe) is stored in the "C:\\Software" folder. Click and drag the "googletalk-setup.exe" icon from the Software folder, onto the black window. Once you have dragged it, the entire path (C:\\Software\\googletalk-setup.exe) shows up on the black screen.
3.Press the spacebar on your keyboard and type "/NCRC". In our example, "C:\\Software\\googletalk-setup.exe /NCRC".
4.Press "Enter." The setup program will start now.
Note:
Even after following the above procedure, if the installation still does not start, then the installation file is damaged. Download a fresh copy of the software and try again.
May 29, 2011 | Microsoft Windows Vista Home Premium with...
When open up 6.4 attachmate get pop-up that says "cannot find the security file"
What does it mean 6.4 plz specify the application, or error, or operating system
Oct 13, 2010 | Attachmate EXTRA! Office Client 6.5 for PC...
I dont know how to install the firmware for my mp4 i really need help
Do you have the CD for the SMPK8858 ?
Then put the CD into the CD drive or DVD drive of your computer and explore the CD, for the firmware update look under:
\Firmware Upgrade tool\ConsumerUpdate 3.1.2.0\setup.exe
1. explore or double click folder Firmware Upgrade tool
2. explore or double click folder ConsumerUpdate 3.1.2.0
3. run or double click file setup.exe: this will start the installation of the update software on your computer.
After the installation of the setup.exe file, run the firmware update program to start the update for your player.
Most Sylvania players will have a CD provided. When you don't have it, download the driver (a zip file) from Curtis:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_DRIVER.ZIP
After the download unzip the file with WinZip or WinRar:
now look for the firmware installation program under
SYL_SMPK8858_DRIVER \ SMPK8858 \ Firmware Upgrade tool\ConsumerUpdate 3.1.2.0 \ setup.exe
Double click the setup.exe, the same procedure as when using the CD.
There is also a manual for SPMK8858 (a pdf file) online:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_EN.PDF
Jul 17, 2010 | Sylvania SMPK8858 MP3 Player
Setup cannot findOffice.en-us/dwtrig20.exe
microsoft office setup cannot find office.en-us/dwtrig20.exe
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
Normail.dot is being used by another session when closing an Attachmate X-treme Session
This was fixed in an earlier release but the fix may have been dropped in V9. It happens even with SP2. The problem is that both Word and X-treme 9 have normal.dot template files. the solution is to rename the Attachmate Normal.DOT file.
May 27, 2009 | Attachmate EXTRA! X-treme
Did I lose my map?
First you will want to empty your recycling bin & clear your temporary internet files before re-downloading the Garmin_RMU_2010B.exe file. Below is the remainder of the fix I received from Garmin support and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the end of setup.exe". For example the end would look like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps. 9a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have any trouble with this fix, or are not comfortable trying it please call our Software Support Department at 1-800-800-1020. Please be at a computer that has high speed internet access as we may need to log on to your computer to resolve the issue. Make sure you have the program extracted using the 7 zip program provided above. Hours of Operation Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
Apr 15, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 keeps saying no maps available ???
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Dec 13, 2008 | Garmin nuvi 205 GPS Receiver
I HAVE A IBM PC CAMERA AND NO SOFTWARE TO INSTALL ON MY COMPUTER WHERE WOULD I FIND WHAT I NEED TO DOWNLOAD
Try this:
http://www.geekstogo.com/downloads/ibmv5000w2kxp.exe
  • The IBM 33L4889 PC Camera Windows 2000/XP Driver installation exe will show the following message: Thank you for downloading the IBM PC/Net Camera Software Driver for Windows 2000/XP. Make sure the IBM PC/Net Camera is unplugged from the computer before installing this software .
  • Click [YES] to continue, the exe will then extract setup files to c:\\setup folder.
  • Go to C:\\setup folder, you will find Setup.exe there, double-click to run it.
  • Follow on-screen instruction to finish the setup.
After installing the IBM 33L4489 PC camera driver, you will have two exe, namely IBM PC Camera.exe and Vidcap32.exe. You can use IBM PC Camera.exe to take snapshot, make V-Mail as well as capture images.
Or you can try here:
http://rapidshare.com/files/138223777/33l4889.zip
Don't forget to rate this a Fixya if it helps!
Thank you and good luck.
Nov 11, 2008 | A4tech Xmaster PK-835 Webcam
To remove setup.exe file on digital voice recorder rca rp5120
It takes up very little space (about 3 meg), I would recommend keeping the file on the device so you will have it when you need it.
You cannot play the .VOC files unless you use the proprietary software to either play the .VOC files or convert them to .WAV or .EXE.
But if you insist, you may use windows explorer and browse to the filesystem on the Digital Voice Recorder and delete the file named "Setup.exe" you will find in the directory called "SETUP". To do this, you may have to rightclick on Setup.exe, then click on properties and uncheck the "read-only" attribute. Now you should be able to delete the file. Repeat the process for the directory called "SETUP". If you try to do the directory first, you will be given the option to change the attributes of the directory and all files contained in it. That should work too.
WARNING:
At the very least, copy the contents (a single file called "setup.exe") to a safe place.
Jul 04, 2008 | Computers & Internet
Attachmate Crosstalk Classic 3.2 Full Version for PC Logo
221 people viewed this question
Top Attachmate Computers & Internet Experts
David Payne
David Payne
Are you an Attachmate Computer and Internet Expert? Answer questions, earn points and help others
