Question about JVC GR-D290 Mini DV Digital Camcorder
Camcorder JVC GR-D290U Will NOT EJECT TAPE
My JVC goes into safeguard mode (02), I have tried to eject the tape but no luck. The motor winds but it sounds as though the gears are not catching. Please Advise. I have tried to troubleshoot via the manual but no luck and no JVC dealers here.
JoeO700
  • 80 Answers
SOURCE: JVC Error Code 02 Safeguard Mode
Brendon, The supply side tape guide can jump out of its track and cause the mechanism to lock up. The load motor is trying to load the tape but cannot, so the load motor driver "times out" and displays the E02 error you're seeing. If you can get to it, try reseating the guide into its track, be careful not to scratch or touch the drum assy located right near the guide track. Good Luck, I hope you can resolve the problem. Joe Weibel customelectronics.org
Posted on Feb 25, 2007
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
kala
  • 156 Answers
SOURCE: E04 Safeguard mode due to Dirt head
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Posted on Jan 08, 2008
kala
  • 156 Answers
SOURCE: jvc GR-D250
There is any error code showing on the lcd screen?
Posted on Feb 28, 2008
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
Safegaurd mode
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Jvc gr-d250u in safeguard mode error 01
Excuse me I'm just 10 years old, but I can surely help you. Have you tried to eject the tape, if not then try. If it does'nt work check the gear works ( the circles with pointy edges that collide with each other to make the tape spin and eject it) that there aren't any little objects in the way to stop it spinning. In my parents camera there was a tiny rock that i took out with a pin.
                                         GOOD LUCK  :)
Jun 02, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D290 Mini DV Digital Camcorder Logo
615 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
